Results 1 to 10 of 15
Thread: 3tc turbo set up for grabs in liverpool sydney
    Senior Member tin can's Avatar
    Jess
    Hi all
    I am selling my 3tc turbo set up in my ke70.
    This is what you get for $2000
    *3tc motor
    *3tc custom plenum
    *3te injection set up
    *stock 3tc flywheel
    *heavy duty 5 puck ceramic clutch kit basically new
    *is200 6 speed gearbox
    *ke70 cross member modified to suit 3tc
    *3tgte exhaust manifold, with adaptor flange ct26 to t3 pattern
    *t3 turbo off a r33 series 2
    *cooler piping to suit ke70
    *radiator with hoses to suit ke70
    *e6x wiring loom to suit this set up
    *crank angel to suit coil packs
    *440cc injectors
    * 3tgte crank not installed
    *3tgte rods not installed
    *308in 288ex wade cam shaft
    * Full 2 ½ in exhaust system to suit ke70 (sedan)
    *w58 to t series tail shaft
    I'm selling this set up because I'm going 3sgte know so I need some money to finish it off.
    This set up makes 115kw on 14 psi.
    If there is anything else that you would like to know about the set up please ask me via pm or call me on 0421820394
    will post up pic's night or 1st thing in the morning
    thanks
    jess
    Aaron
    In the Mountains
    holysmoly!
    dose it come with a tailshaft and to suit what diff??
    seems uber cheap, i bet the geaarbox would be worth 1k or more
    14psi threw a std n/a bottom end?? has it been recondition?
    Jess
    yeah i have got a tail shaft to suit it ( t series rear end)
    14psi through a stocker bottom end loves it the motr would take 20psi easy
    thanks jess
    i will ship it
    Aaron
    In the Mountains
    would you consider parting it out?
    it dosent come with ecu??
    i know 3tc's are very strong motors but I'm not sure about it handling 20psi for a long time. although 3tgte stuff would be sigificantly asstronger i would imagine.
    Jess
    ae71
    I'm really keen on parting out what do u need
    no comp but a complete loom
    3tc's are strong but I'm looking for somthing new
    thanks
    jess
    Aaron
    In the Mountains
    PM'd
    Ross
    Keen on:
    * 3tgte rods not installed
    * 308in 288ex wade cam shaft
    Got full specifications on the Wade?
    Any modifications needed to use these parts in the 3tc? Any major gains from using them? Sorry new to the 3TC market
    Jess
    fusion
    mate sorry i don't reaaly want to seperate this package
    no mods needed all these items bolt in to a 3tc
    gains
    cranks in double counter weights bit more torque and rpm
    robs thet are bigger
    thanks jess
    Jordan
    Prospect
    Thins might sound odd but can you email me the pictures, as the only net access I've got since I've moved is at work and they block hoasted images. email is 'manitoublack@gmail.com'
    jordan
    Future ride:
    FT-86.
    Current rides:
    CAA22 Celica, 2000 Caldina GT-T manual, 1966 RT40 corona,
    Previous Rides
    86 hilux, 4xKE55's, 3xTA22, RA28, 2xRT40, 2xST185, KE10, 180B, RT132
    Jess
    jfallen
    email sent
  1. WTB: AE71 MANUAL Pedal box Sydney,Liverpool
    By ghetto ke in forum Cars or Parts Wanted
    Last Post: 10th May 2010, 01:21 AM
  2. WTB: AE71 Manuel Pedal box Sydney,Liverpool
    Last Post: 30th March 2010, 02:13 PM
