Results 21 to 30 of 50
Thread: AE71 Spirit - 4age - LSD - Grip Machine
Threaded View
    West
    Default AE71 Spirit - 4age - LSD - Grip Machine
    Hey guys. This is my car. The body is untidy, but fairly well rust free. Its an 84 model. Specs are as follows:
    Motor and Driveline:
    AE101 20 valve Engine
    AE111 ITBs with Uni Filter Socks
    AE111 Flywheel with standard AE111 clutch
    AE111 Alternator
    Cusco Hard Rubber Engine and Gearbox Mounts
    AE86 JDM T50
    AE86 Kouki 2 way LSD 4.3:1 diff and JDM AE86 tail-shaft
    Adaptronic ECU and COP Ignition
    AE86 Starter Motor
    Yager Motorsport Thermostat relocation fitting
    65 Degree C Dayco Thermostat
    T3 Water Underdrive pulley
    Recored standard Radiator with 16 inch thermofan
    Kaizen 4-1 Headers
    2 1/4 Exhaust with Magnaflow cat over diff style
    Kaizen Billet Dizzy Cover
    Alloy Air Diverter/Heat Shield
    JDM AE86 tank and pump
    Suspension/Brakes
    ST185 Koni Sport Adjustable front Dampers
    TRD Green 8 Way Adjustable rear Dampers
    Cut and Weld Coilovers made from AE86 Struts
    New Jap Wheel Bearings
    Unknown brand of front springs - approx 6-7kg rate
    Rear springs are shortened standards
    Whiteline Front AE86 Swaybar
    Whiteline Rear AE86 Swaybar 18mm (comes out for hills runs)
    Tein Camber Plates
    Quaife Quick Rack
    RA40 Tie rod ends
    XT130 LCAs
    T3 RCAs
    New PBR AE71 Master Cylinder
    Front Brakes are the Wilwood 280mm Brake Kit from T3
    Rear Brakes are JDM AE86 Discs and Calipers
    Cusco front strut Brace
    Ultra Racing 4 point rear brace
    Modified Towbar Brace
    Ultra Racing Fender Braces
    Whiteline Adjustable panhard rod
    Nolathane Bushes all round
    Wheels
    Unknown brand of Japanese 15x7.5 +20 fronts with a 205/50 tyre
    SSR Mk 3 15x7 +13 Rears with a 195/50 tyre
    Spare is a Nissan Space Saver cause it fits under the 4 point brace in the boot
    Interior
    Recaro Recliner For the Driver
    CSX Velour Seat for the Passenger
    Adaptronic Vidigauge Unit
    Modified Dash face
    Sony Head unit and 2 6x9s on rear shelf
    Shift lightsx2 one at 6800 and one at 7500
    Plans for it? Hit the track in 2009...
ID:	304   Click image for larger version.
Name:	arty shotsmall.jpg
ID:	305   Click image for larger version.
Name:	new bits diff 005.jpg
ID:	306   Click image for larger version.
Name:	cold air setup 006.jpg
ID:	307   Click image for larger version.
Name:	new gaurd 004.jpg
ID:	309   Click image for larger version.
Name:	speed camera shot.jpg
ID:	310   Click image for larger version.
ID:	311   Click image for larger version.
  1. The Green Machine - AE71 4AGTE Pano Build
    By Futo_gt86 in forum KE70 / AE71 Owners Forums
    Last Post: 12th April 2019, 04:55 PM
  2. 4age into my ae71 spirit
    By 84spirit in forum Technical - Questions
    Last Post: 16th July 2011, 07:04 PM
  3. My 4age AE71 Spirit.
    By Drift_Donkey in forum KE70 / AE71 Owners Forums
    Last Post: 8th November 2009, 07:36 PM
  4. AE71 Spirit
    By 84_AE71 in forum KE70 / AE71 Owners Forums
    Last Post: 3rd July 2008, 08:12 PM
