Results 1 to 3 of 3
Thread: carrier/pinion preloads
    Senior Member Johnny_K's Avatar
    kiara
    Ok got myself a new 4.5 crown wheel and pinion now time to fit it up, just wondering if anyone knows the carrier and pinion preloads for the bearings ? THANKS
    Benn
    gold coast
    <div class='quotetop'>QUOTE (Johnny_K @ Mar 12 2008, 11:50 PM) </div>for new bearings/crucshtube: pinion is about 8-10nm after break-away(without carier fitted), 4-5nm if you using old bearings
    carrier should be nipped up tight, then backed off 2 -3 notches(more if old bearings). then set lash and contact. about .2 to .4 of a mm for lash(again more if old).
    then contact: to much heel, move the wheel....blah, blah, blah, I'm sure you can find a tooth contact chart.
    edit: these arn't exact toyota specs, just an idea. i usually set them up by feel. but if someone has a workshop manual just for peice of mind
    Oldschool Member
    Mar 2006
    Jamie
    sa
    northern suburbs
    <div class='quotetop'>QUOTE (Benno @ Mar 13 2008, 07:00 AM) </div>
    i set my pinion up similarly, but with the carrier bearing preload i use a dial indiactor on the opposite aldjuster you are winding in, and when the free play is out it will start reading on the dial indicator, then as per toyota used bearings give it one extra knotch and new give it two knotches......as far as the back lash goes factory specs are .13mm to .17mm........i always check the back lash in a minimum of 4 places, often one will be good and the others will be way off.....if this happens i rotate the crown wheel on the diff and recheck.....
    i enjoy setting up toyota diffs, cause its easy to get it the way you want it....compared to borg warners
  1. diff carrier stand
    By 96sonataBro in forum Tool Talk
    Last Post: 29th July 2012, 01:07 AM
  2. WTB: S series pinion carrier or complete diff in victoria!
    By hachi_dk in forum Cars or Parts Wanted
    Last Post: 23rd March 2012, 11:43 PM
  3. Nissan car carrier
    By chucky in forum Cars for Sale (Not Toyotas)
    Last Post: 9th November 2009, 09:23 AM
  4. bearing carrier...
    By fantapants in forum Technical - Questions
    Last Post: 1st November 2009, 07:57 PM
  5. T series Centre Carrier.
    By Ru-iki in forum Cars or Parts Wanted
    Last Post: 24th July 2008, 05:58 PM
