Results 1 to 10 of 14
Thread: engineering an sr20det ke70??
    Nic
    Mt Evelyn
    Default engineering an sr20det ke70??
    hey guys I'm building an sr20de+t ke70. it will have s13 front coilover suspension with sr20 brakes. rear end will have r31 diff with r31 disc rear brakes. engine mounts will be very well fabricated. and I'm not sure what else needs to be done.
    Nic
    Speak to an engineer. Get a list of the licensed ones of the Vicroads website or call them and they will mail it out.
    Find out what they want/don't want to see before you get in too deep.
    Nic
    Mt Evelyn
    yeah i have done this now. but was just wondering if anyone else has done it.
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    <div class='quotetop'>QUOTE (Nic19 @ Mar 22 2008, 07:35 PM) </div>
    I spoke to an engineer he just said brake upgrade and cat on the exhaust... brakes same size as car it came off and bigger wheels 15 or 16 inch....
    Andrew
    It can be done. Engine has to be stock unless you want to spend $1500 per test at the EPA. Just bolt it in, stock ecu, stock type cat etc. It's mainly the pollution stuff that they are worried about. I'm not even sure that you have to upgrade the brakes as in, I don't know that there are any regulations that require it.
    It has to be a neat job too.
    leigh pidwell has done it but i couldnt be too sure how you could get in contact with him,
    if you went to driftfest last year that white ke70 had an sr in it and it was rego'd
    Calvin
    Kilsyth
    hahaha rego'd but definitely not engineered lol. leigh wouldn't have a chance in hell of gettin his pig engineered
    T18 in the build
    why not?
    Calvin
    Kilsyth
    its not the cleanest conversion or the cleanest car as leigh is worried about functionality and getting it done quick rather than appearance and neatness....
    T18 in the build
    Senior Member shakes's Avatar
    Simon
    Vic
    Melb
    <div class='quotetop'>QUOTE (Hokey @ Apr 3 2008, 03:33 PM) </div>my ute cut is far from what I'd call neat and pretty, but it is very very functional and due to this the engineer was happy.
    Providing you can prove the brakes/susp came from an sr20 spec'd car. with part numbers and such and that engine/gearbox mounts are well made, maybe with a bit of gusseting in the frame. ie strut brace to firewall rear strut brace and a few other bit's. I can't see why it wont be engineered. unless your using 12gauge plate for mount's and wiring everywhere.
    A couple of day's to tidy little bit's up, zip tie and conduit stray wires, paint welded bits works wonders for how good thing's look. engineers are also worried about longevity, they way they look at it is 3 owners down the track someone loses control and put's it into a tree they get called to the stand for manslaughter because they said the car was safe.
    Simon
  1. [vic] ke70 sr20det
    By tshaw44 in forum Cars for Sale (Toyota Only)
    Last Post: 23rd June 2012, 07:46 PM
  2. SR20DET KE70, 322HP
    By GOODY in forum Ebay Items - My Stuff
    Last Post: 23rd January 2012, 09:19 PM
  3. KE70 sr20det
    By craig2 in forum KE70 / AE71 Owners Forums
    Last Post: 1st December 2010, 08:11 AM
  4. SR20DET into KE70 Parts
    By ke70 xx in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 06:15 PM
  5. Ke70-SR20DET
    By gze-style in forum KE70 / AE71 Owners Forums
    Last Post: 17th June 2008, 01:41 AM
