Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: aftermarket ecu
  1. #11
    Ru-iki
    <div class='quotetop'>QUOTE (drftr86 @ Mar 23 2008, 01:36 PM) </div>
    Why don't you just lock the ignition, and batch fire the injectors too. In my opinion you should take full advantage of the features available to you or you are just flushing the money down the toilet. If you feel different, thats fine by me. Gives me an advantage.
    By the way you never answered my question. So I ask again, how is it unnecessary? Explain it to me.
  2. #12
    Elite rthy's Avatar
    Leo
    Tulla
    I have to agree here, the air temp sensor is there for a good reason and anything else is a comparmise at best and at worst a blown engine.
  3. #13
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    does repco or any other place sell universal air temp
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
  4. #14
    Elite rthy's Avatar
    Leo
    Tulla
    well I don't know about other ECU's but the wolf ECU uses a generic holden one. Ask the maker of the ecu whats compatable
  5. #15
    Richard
    South Oakleigh
    i can use any i geuss as it has 1 signal wire for air temp and shares the earth with the map and coolant temp sensors, does the holden one have a 2 pin type sensor????
    SQ ENGINEERING
    NCCE
  6. #16
    Ru-iki
    Pretty sure adaptronic an use any old one. Might need to calibrate. Try the adaptronic forum for some answers.
  7. #17
    Richard
    South Oakleigh
    yeah i wouldn't be suprised if i could use the old one, but i sold me jdm rwd manifold a while ago and don't have a air temp sensor any more, think of raiding the wreckers
    SQ ENGINEERING
    NCCE
  8. #18
    Ru-iki
    You will be amazed how much better it will go on a cold vic night with a bit of positive trim. How else can you take full advantage of the cold climate?
  9. #19
    Richard
    South Oakleigh
    true true, thanks for the advice once again, will be looking into it, probably just raid one from the wreckers
    SQ ENGINEERING
    NCCE
  1. What's the best aftermarket ecu-4agte
    By john84ie in forum Technical - Questions
    Last Post: 9th May 2014, 02:58 AM
  2. Which Aftermarket ECU?
    By JDM-086 in forum Technical - Questions
    Last Post: 11th April 2014, 09:54 PM
  3. Need some one to wire up aftermarket ECU ?
    By AIROCOBRA in forum Canberra & ACT Events and Discussion
    Last Post: 11th December 2009, 03:28 PM
  4. AFTERMARKET ECU
    By drif86s in forum Cars or Parts Wanted
    Last Post: 10th March 2007, 11:10 PM
