Results 1 to 10 of 11
Thread: Help - 3 RHS rear hub stud threads ruined AE86
    Oldschool Member
    Mar 2008
    sidey
    vic
    melbourne
    one dodgy nut ruined one thread then it ended up on another thread and so on... (one thread end had even snapped off trying to remove the nut as pictured.)
    do i need to change whole RHS axel ?
    I have taken the drum cover off.
    and i can see the studs are press fitted by the looks.
    can't really drive with one wheel nut on, may be able to force one other on to get it to a mechanic.
    Should i take out the axel and have new studs pressed in ? or just buy a good second hand RHS axel.
    are these easy to get a hold of ? anyone have one for sale ? (I'm about 10km NNE of Melb)
    i have to get this fixed asap - its a daily driver...
    thanks for any advice.
    [attachment=23689SC05693.jpg]
    [attachment=23690SC05694.jpg]
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    its cheaper just to get the studs about 6 bucks each from repco
    just diy its not to hard
    Oldschool Member
    Mar 2008
    sidey
    vic
    melbourne
    Thanks for the quik reply,
    But the press stud fitting can't be done at home doesnt that have to be prefessionally done with a machine ? or not...
    i would still have to remove the axel from the car to get the new studs in too I'm expecting.
    Dave
    <div class='quotetop'>QUOTE (Sidey @ Mar 14 2008, 09:22 PM) </div>nah man its easy as
    you should be able to just smack the old studs out,
    then put the new studs in, and put a wheel nut on it, and tighten up the wheel nut which will force the stud into place.
    done this a few times, works well.
    you might be able to do it with the axel in, not exactly sure if there is enough room. you could just take out the brake shoes too, that will give some more room to play with.
    - Blaise Pascal
    john
    nsw
    liverpool
    id say take the whole axle out to be be on the safe side .... don't want to damage the diff ... should be easier enough to take the axle out ... and then take the studs out ....
    parrot
    No, easy as. Just tap them out with a punch. Then pull them back in as described above.
    If you prefer, practice on something at pickapart first, and then pick up some studs for free whilst you are there. Just make sure they are the same thread.
    Oldschool Member
    Mar 2008
    sidey
    vic
    melbourne
    <div class='quotetop'>QUOTE (ke70dave @ Mar 14 2008, 10:28 PM) </div>Thanks ke70dave i'll give it a go. i smacked oen stud a few times but its loud and people are asleep but it moved maybe 1/2 a mm so it looks like it will come out.
    is what redsprinter saying true ? if I smack it is there a chance sumthign will happen to diff ? doesnt quite sound right - i havent undone the backing plate 4 bolts that join to the axel housing. so i wouldn't have thought anythign could go wrong except mabye warping the hub trying to get the studs out ??? with successive hits ?
    will continue hitting in the morning (and ke70dave i can leave the brake shoes assemly there, just turn the stud to a spot where there is plenty of room behind and hit away
    glad to hear u have replaced studs b4. i'll try to get some tomorrow hope they are in stock at repco or I'm screwed. 6 bucks each huh?
    Oldschool Member
    Mar 2008
    sidey
    vic
    melbourne
    Ahh parrot has basically confirmed. Thanks for that. hehe its very rare to ever see a sprinter at pickapart, but some other toyotas would have same studs i guess... if i go, i'll bring a nut and a stud with me perhaps.
    parrot
    Take a nut to be sure. Lots of the rear drive Toyota's ate the same. Also magna etc (longer and newer)
    See including SamQ's FAQ link.
    You don't need to hit them too hard, and put some WD40 on the stud when you pull it into your axle.
    You can just knock out the old stud as suggested and use the wheel nut to pull the new one in. As a mechanic i would never pull the axle to do this job. It is perfectly fine/safe to do it this way. Go genuine also with the stud.They are the best ones to get.
  1. ke70 - rear stud replacement
    By KKUSTOM in forum Technical - Questions
    Last Post: 1st August 2009, 07:53 PM
  2. How to remove rear hub?
    By AE86R in forum Technical - Questions
    Last Post: 14th January 2009, 12:16 PM
  3. hub/stud conversion
    Last Post: 15th June 2008, 03:52 PM
  4. WTB AE86 - Bonnet, RHS Front Guard, RHS Headlight, Grille
    By tan18d in forum Cars or Parts Wanted
    Last Post: 30th January 2008, 07:12 AM
