Results 1 to 10 of 19
Thread: Car leaks some sort of liquid
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    Hey guys my kouki trueno leaks a oily, green in colour liquid.
    It comes just from behind the fire wall on the inside of the car and always wets the passenger upper right hand side carpet
    (closet to the tunnel)
    i was suspecting aircon has a leak?
    Senior Member 350hp4agte's Avatar
    underwood
    qld
    jimboomba
    heater more than likely
    gunbz-r
    ^^^yup
    john
    nsw
    liverpool
    coolant from the heater ....
    Veteran biggo's Avatar
    Nick
    Noosa
    OILY green! a/c refidgant in cars is coloured green for a reason.
    if it really is oily then thats bad
    if its watery you probably wont get cancer
    Benn
    gold coast
    fluro greeny/yellow is a/c dye, it usually mixes with the compressor oil.
    as biggo said, don't touch it!
    Got a black light ?
    Wave a black light/UV light over it and if glows you air con is leaking.
    Noticed coolant levels changing, By-pass the heater and see what happens.
    Jun 2009
    Damian
    <div class='quotetop'>QUOTE (biggo @ Mar 15 2008, 11:58 AM) </div>what do u mean by that?
    Nick
    Noosa
    hmph
    theres a difference between water and oil usually. IF it is oil and you have touched, well thats bad to say the least
    Jun 2009
    Damian
    <div class='quotetop'>QUOTE (biggo @ Mar 15 2008, 11:12 PM) </div>hmm are you trying to say its bad for me?
    or the cars got a cracked head???????????
  1. any sort of car panel for practise welding(cheap)sydney
    By s13 james in forum Cars or Parts Wanted
    Last Post: 23rd June 2011, 04:39 PM
  2. Liquid Propane Gas Injection
    By sundee in forum Technical - Questions
    Last Post: 8th February 2010, 03:33 PM
  3. Oil leaks at distributor...
    By AE86.cn in forum Technical - Questions
    Last Post: 5th February 2008, 09:26 PM
  4. 86 Hatch leaks
    By v-tec in forum Technical - Questions
    Last Post: 23rd August 2007, 03:34 AM
