Results 1 to 5 of 5
Thread: What oil should i run in a 20V daily car???
    as above also id like to be good quality price isnt much of an issue up to 100bux
    Sly
    Qld
    hey antoun,
    have a read up on this
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    Penrite sin
    <div class='quotetop'>QUOTE (AE86_4life @ Mar 15 2008, 10:27 PM) </div>Km's on motor ?
    15w40 semi synthetic if the km's are a bit high or 10w40 if the motor is fresh. I found my 16v runs better on 15w40 than 10w40, Just starts easier etc.
    Valvoline duragear 15w40 is about $40 for 5 litres, There is oil called purple stuff or something like that and apparently its good shit but haven't been able to find it for sale yet
    Jonathan
    Generaly, I think you could run just about any engine oil and you would hardly notice the difference. If the valve stem seals and rings are a little old, you may burn a little oil. You can then experiment with thinner or thicker oil to reduce oil smoke. If you have a oil pressure gauge you may notice differences also. But other than that, you are not likely to realize any difference unless you send a sample of used oil to a lab for testing. So for me, I go with the cheapest oil.
  1. cheap run around , daily car (Adelaide)
    By GT-LEGACY-GT in forum Cars or Parts Wanted
    Last Post: 15th December 2011, 07:30 PM
  2. my 84 ae71 daily driver + project in the long run
    By ae71yo in forum KE70 / AE71 Owners Forums
    Last Post: 27th August 2011, 05:44 PM
  3. can you run an oil cooler between your remote oil filter
    By kali_man_tan in forum Technical - Questions
    Last Post: 8th June 2007, 12:33 PM
  4. Car seems to run on 3 cylinders
    By RB20DET_Silvia in forum Technical - Questions
    Last Post: 16th February 2006, 02:29 AM
