Results 11 to 20 of 23
Thread: Bee*R Rev Limiter on a non ECU car? can it be done?
  1. #11
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    ahh yep i see
    MY JZX83 (clicky)
  2. #12
    Senior Member shakes's Avatar
    Simon
    Vic
    Melb
    <div class='quotetop'>QUOTE (GZE KE70 @ Mar 16 2008, 02:02 PM) </div>
    hell yea :2thumbs:
  3. #13
    The BeeR limiter will work.
    I read (admittedly in a mag ages ago) that the BeeR works by grounding out the ignition output(s) when the rev limit is reached. Therefore no spark, therefore flames out the exhaust.
    You can do the same on the coil on your 4AC (or any other carbed car). The coil negative wire is earthed through the points and sparks when the points open and the wire is no longer earthed. If you wire the BeeR up so that it earths the coil negative wire above the rev limit it will work as normal.
    And if you use the above shift light technique, rather than using a relay, use a transistor. They are slightly more complicated to setup, but are smaller and far more reliable when switching often and fast.
  4. #14
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Sounds like you just want the flamage and backfiring and not really much else. Don't worry about rev limit if you want to drift with a 4ac, it wont die anyway.
    Know any autosparky's? Get him to hook up a switch with a sparkplug in your exhaust and all the rest, so when you hit it it will ignite the raw fuel, same effect but cooler.
  5. #15
    Site Supporter Javal's Avatar
    Josho
    <div class='quotetop'>QUOTE (GZE KE70 @ Mar 16 2008, 01:32 PM) </div>
    That is all.
  6. #16
    Paul
    West
    cut a hole in ur exhaust weld a nut screw in a spark plug wire it up on a switch BINGO! instant fun!
  7. #17
    Reza
    Jakarta
    Eastern Jakarta
    Indonesia
    Bingo maybe if you ran it rich all the time, you would need raw fuel delivery aswell to make it REALY worth it haha flame-thrower anyone?
  8. #18
    Benn
    gold coast
    go buy one from jaycar and assemble it, they're about $50 and have the neat led's like the bee*R.
    they also have a hysteria adjustment for soft or hard limits
  9. #19
    Dave
    the jaycar kit he is talking about is this one
    i just found it, thanks brenno for letting me know about that
    its heaps cheaper than the way i was describing above, 35$ is a bargain!
    - Blaise Pascal
  10. #20
    Benn
    gold coast
    I've actually got one with a 4 led(3 green, 1 red) display for the shift point and a adjustable limiter when the red comes on.
    I'll be buggered if i can find the kit now, might have been a DSE kit
  1. bee-r rev limiter
    By bones in forum Car Parts For Sale
    Last Post: 25th June 2010, 04:34 PM
  2. Bee R Rev Limiter
    By trueno85 in forum Cars or Parts Wanted
    Last Post: 10th February 2010, 01:52 AM
  3. Bee R rev limiter- melbounre
    By meat axe in forum Car Parts For Sale
    Last Post: 5th November 2009, 09:31 PM
  4. BEE-r rev limiter to microtech
    By dr1ft-pig in forum Technical - Questions
    Last Post: 31st July 2008, 11:29 PM
