bump faggots.
Suggested solutions:
Fuel filter filled with crap
Something dizzy related?
HALP MOI.
Hi all.
Need your help urgently:
Car: XT130 Corona, Motor: 1x (holden starfire 1.9L)
Symptoms:
Bad idle, missing at idle, cutting out
Stalling whenever you bring it back to idle
Basically running like a sack of crap
Was running great before saturday afternoon, only thing that has changed since then was i put some 95 octane in it (instead of 91 like normal, yeeeew).
Have fixed all vacuum leaks, adjusted idle speed / mixture, choke etc etc.
Still can't work it out.
HELP I NEED THIS SHIT RUNNING TOMORROW.
bump faggots.
HALP MOI.
so if you bring it off idle, its ok.?
maybe you got a shitty batch of fuel......its an outside possibility.
carby cleaning the throat made no difference?
if you can get to the top of the carby, are you able to remove the bowl? inspect inside there and the float
it might be a dodgy fuel pump, split in the diaphram causing not enough fuel at idle
<div class='quotetop'>QUOTE (slide86 @ Mar 16 2008, 09:24 PM) </div>Carby cleaner didn't do fuck all.
I fail at the carbys.
basically if i put my boot into it, it's great
just not at idle![]()
Idle jets blocked ?
<div class='quotetop'>QUOTE (GZE KE70 @ Mar 16 2008, 09:34 PM) </div>I'd hope not.
i managed to borrow my friends car for what i need to do tomorrow, so i might just say 'fuck it' and give it a good going-over through the week and if i can't work it out, then just slap a 32 / 36 on it and replace everything.
yeah thats my guess. i think the idle port has a block in it
this port is BELOW the throttle butterfly. so you will need to have WOT to see it. shine a torch down the carby and you will see a small hole. this is the idle port.
don't DROP ANYTHING DOWN THE CARBY
<div class='quotetop'>QUOTE (slide86 @ Mar 16 2008, 09:38 PM) </div>BUT I REALLY REALLY WANT TO
Yeah will do tomorrow.
Anybody else who has other suggestions, shoot, cause i'm going to try them all tomorrow.
the extra octane may of pulled carbom of the inside of the motor and its fouled the plugs. simple yes, happens alot tho
