Results 1 to 10 of 17
Thread: Installing AE86 front springs
    Oldschool Member
    Mar 2008
    sidey
    vic
    melbourne
    I have a pair of front springs - Lovells for AE86 - apparently 30mm lower than Standard (came with car) still in box. Wanting to replace the cut springs that came with the car when purchased.
    Anyone have any opinions on these springs for a daily driver, anyone else use these springs ?
    I have searched both tech sections and noone has specifically said they have changed their own springs & how easy/hard it was. I didnt think it would be very difficult but not sure. I dloaded the PDF for the AE86 manual but not sure it specifically deals with just focussing on straight-up remove and refit springs. it goes into how to undo everything... . They talk of spring compressors too which i don't have but i thought i might be able to get away with it considering the free standing height of the cut springs and the new springs will both be shorter than stock/
    Is there a quick way to just remove and fit springs ? a quick procedure rundown if you've done it before?
    Secondly, i believe the car will sit a bit higher as a result. would you agree i will need to get a wheel alignment done too ? It had previously been set with a bit of toe-in and obviously had a bit of neg camber due to the cut springs.
    Will i need to replace front shocks too. I am unsure what is curently in there (mandrel blue i think)?
    Thanks for any thoughts.
    Jonathan
    It is a regular job any mechanic can do easily with the right tools. And any backyard mechanic can do it also, even with the wrong tools.
    It is best to just get out your tools and have a go.
    Oldschool Member
    Mar 2008
    sidey
    vic
    melbourne
    <div class='quotetop'>QUOTE (Jonny Rochester @ Mar 17 2008, 12:23 AM) </div>Is there a more direct procedure than the AE86 manual ? go you have basic guidelines or is it a bit too involved to explain in a forum? suspension is one of the things i have worked least with...
    Veteran biggo's Avatar
    Nick
    Noosa
    its not really hard
    pull wheel off
    unbolt caliper
    unbolt strut
    pull strut out
    Depending how long your shocks/spring combo is you may need a pair of spring comprssors
    VERY IMPORTANT- to get the strut tops off i just grap a rag and muulti grips and grip the very top of the shock piston to undo the strut nut.
    there now just do it in reverse
    Jase
    South Australia
    Glenelg
    easier to loosen strut top bolt before the car is even jacked up. Getting a mate to sit on the quarter panel helps if the shock just spins.
    Veteran anastasios's Avatar
    Taz
    Earlwood
    man just take a look at what bolts connect to what, start by jacking the car up u don't need no takumi manual to take out a spring especially if they are cut
    Oldschool Member
    Mar 2008
    sidey
    vic
    melbourne
    i do want to give this a go, but still a bit unconfident purley because i've worked on almost all other components and electricals except for suspension...
    a guy who doesnt own an ae86 mentioned that if you undo the lower controll arm it could be done without remove the nuts from the strut tower in the engine bay, I'm guessing this is not an option with the ae86.
    i think i will just make a start. yes car is jacked up and wheel is off since last night.
    will it all go back together without affecting alignment castor and so on if i just try to wing it based on "biggo"'s guide?
    [attachment=23762SC05695.jpg][attachment=23763SC05697.jpg][attachment=23764:
    DSC05698.jpg][attachment=23765SC05699.jpg]
    Nick
    Noosa
    i see what your mat means
    the way Guille and I are stateing it, you LOOSEN the strut nut but don't undo it. leave the strut top on when you take the strut out. If you undo it, you will really need to strong arm it back in cos they can get quite heavv after 2 or so mins.
    You can leave the lower control arm in too, just loosen it
    Taz
    Earlwood
    take off 3 top bolts, take off 2 bottom bolts take off caliper, the end
    Oldschool Member
    Mar 2008
    sidey
    vic
    melbourne
    <div class='quotetop'>QUOTE (anastasios @ Mar 17 2008, 01:10 PM) </div>why take caliper off btw? no need to remove brake line though is there?
  1. SA - 6KG AE86 front springs and 8KG coilover springs
    By Konakid in forum Car Parts For Sale
    Last Post: 13th September 2012, 08:19 PM
  2. AE86 front springs
    Last Post: 29th July 2012, 01:18 AM
  3. Standard KE70 rear springs and AE86 front springs in SA
    By Seventy in forum Cars or Parts Wanted
    Last Post: 8th February 2012, 02:28 PM
  4. AE86 front springs + inserts
    Last Post: 17th September 2011, 09:34 PM
  5. stock ae86 front springs
    By jeff in forum Cars or Parts Wanted
    Last Post: 21st April 2009, 02:58 AM
