Results 1 to 10 of 17
Thread: Diff Whine Help??
    When I first got my LSD installed it was fine making hardly any noise. But after driving the car for a while it was gradually getting a bad noise. It seemed to get alot worse after taking the car out to Willobank drags for a night.
    The Diff/rear end is from a Hilux and is using a LSD from a new model hilux which has been shimmed/tightened before I bought it to the point of where it acts just like a locker. I'm also only using normal diff oil, not LSD.
    The noise happens whenever I back off the throttle completely, only a very slight whine that I can hardly hear when starting to accelerate. It has a sort of crunching/whining noise when I let off completely. New carrier bearings went in with the LSD but that was all.
    Anyone got any ideas as to what it is???
    Site Supporter Javal's Avatar
    Josho
    Use LSD oil.
    Stefan
    Parkinson
    banana peel
    Like Javal said USE LSD OIL, Normal diff oil in a LSD centre is a big no no.
    Bananna peel lol? I'll get some LSD oil tommorow and throw that in. Would that most likely be the cause of the problem?
    Would I have done damage?
    Richy
    put some banana peels in there to stop the whine lol...but seriously LSD OIL MAN! not sure what sorta LSD it is but the clutch packs within usually need special oil
    Lol ok cool, I'll get some oil tommorow and throw that in. Should it stop the whine or just be better for the actual diff?
    It could make it silent again or using the wrong oil may have fucked it.
    If its damaged the damage will be in the clutch plates.
    Benn
    gold coast
    i'd suggest some nulon oil stableizer too, it's good shit
    what about wheel gearings or diff bearings?
    i have just changed my diff and it has whining and its not LSD and has LSD oil, would this create whining? or the bearings?
    sorry to hijack just using this to sort things out
  1. diff shops/whine issues anyone?
    By tezza88 in forum Sydney & NSW Events and Discussion
    Last Post: 25th July 2011, 08:01 PM
  2. whine in steering when turning left
    By blake. in forum Technical - Questions
    Last Post: 26th October 2009, 07:32 PM
  3. Diff Whine - Making it quieter?
    By Golberg in forum Technical - Questions
    Last Post: 13th April 2009, 07:33 PM
  4. diff with crazy loud whine
    By wanabdrifta in forum Technical - Questions
    Last Post: 12th November 2007, 07:33 AM
  5. Diff whine - Suspected CW&P
    By damo46 in forum Technical - Questions
    Last Post: 14th August 2006, 05:30 PM
