<div class='quotetop'>QUOTE (drft86 @ Aug 20 2008, 08:09 PM) </div>13:1 CR and 2 bar.. HAHAHAHAHHA what type of rocket fuel you using and where you get it from cause I want it
<div class='quotetop'>QUOTE (v-tec @ Aug 20 2008, 07:20 PM) </div>Will this work well with my turbo setup. I wanted to run 13:1 compression and 2bar of boost. will these cams help me achive my 300rwkw goal. Do you know if it will be laggy. What shim setup is used. They are new reground trd's arent they?Will this setup bolt it?
If so will you deal with it and take $40 posted?
yo grant. prolly take it? its the whole head? or just the cams now? lemme know will save me some fuss..
78's
whole head
<div class='quotetop'>QUOTE (slipper86 @ Aug 20 2008, 09:57 PM) </div>probably just bp95 should do it. think you'll find your local service station has it
I think the "AND" is meant to be an "OR" seriously guys 13:1 CR is HEAPS on its own. I mean Ive seen car being tuned that have had 13:1 CR (4AGE) and they didnt like it one bit. that was with 98 optimax and the only time it liked it was with octane booster. no amount of playing with ignition timing stopped it from ping ping pinging its head off. NOW you want to increase the clyinder pressure again by adding 2 BAR of boost. WOW. On a similar note Ive seen 4AGTE's AE101 GZE bottom end version running 26PSI (1.7ish BAR) and have issues with detonation and that has 8.9:1 CR.
I say GOOD LUCK.. it will either last 1 big rev or will have no power because of the constant rattle. UNLESS you are running methanol or its a diesel
dude hes obviously joking...... this is the internet, nothing on here is true. these cams arent even really cams, theyre chickens on steroids.
Jason get out my thread and my life
Seriously, you shut your mouth when speaking to me
hey mate I'm interested but will this work on stock ecu?
Nah it will require some sort of aftermarket ecu, i think the biggest duration you can run with stock is 276
