get a seat brace up yah!
but those gumby braces go on the shock towers, i would weld a bar between the two if i was you
after some shots of 86's running rear strut braces (above shocks/behind rear seat?)
so i don't drill holes in the wrong spot bahah.
i have a T3 Item..
cheers!
shock towers = above the shock right?
theres no way its fitting below..
you know that this part is for decrative purposes only don't you?
<div class='quotetop'>QUOTE (Sam_Q @ Apr 10 2008, 07:00 AM) </div>u can hang ur wet socks on it
honestly its 50% for the fact that it might do something
50% cause I'm sick of evry fucking person calling my car a shitbox still
when ive poored like 7grand into it from stock
I know what that feels like
haha
mm but at least in your case its alot of custom fabrication etc
mines just buy shit and bolt it in
only problem is its all under the car/engine bay
and my shell/panels/paint/rust are less of a priority
(just wanna be able to Drift the fucker again!)
sell it then and use the money to fix ur motor...
you don't need to look like you drift, just drift (y)
