Have a 4agze conversion in my sprinter, haven't been doing a lot of driving but have recently fixed my major gearbox/diff driveline problems so was keen to get out and about more.
Now I've started driving it I've suddenly got new issues. When I start the car I get clouds of blueish smoke out the exhaust, would seem like oil burning. The smoke decreases a fair bit when the engine warms up to full temp, but there is still evidence of some smoke, particularly when I give it some throttle. If I start up the next day or even a few hours later smoke is back again.
I would normally think things like rings or valve stem seals etc, however when I bought the car it wasn't doing it and had apparently done less than 10,000km after a rebuild of the motor. It should be all fine.
I don't remember it happening in the limited driving I've done, in fact I've only done another 1000km since, and it seems to have only just started happening.
For a bit of background, I run a microtech ECU which may run a little rich at times, but I wouldn't think this would cause blue smoke. I also have a front mount cooler. Have also noticed the plugs look blackish and have become fouled at times.
I don't know if the oil is getting in another way, perhaps its the oil I'm using (Magnatech 10W40) I don't know what oil the original owner used though. Maybe supercharger related? I'm really not keen to pull the head off so would like to try all other possibilities first.
Any Ideas?
Thanks
paul
