Results 1 to 3 of 3
Thread: 4ac idle problems
    Jarrod
    Magill
    hey,
    not long ago my 4ac was havin a few problems while givin it a raping
    got a shitty idle and once it spluttered for a few mins then magically fixed its self.
    lately my idle has been shit, really low, jumps up n down and usually cuts out
    i couldnt figure it out n assumed the carby was fucked so i threw a new 1 on and it fixed everything.
    that was a few days back, went for my 1st descent thrash with it 2day and i got the shitty idle again, a few times after i let it sit for a bit n turned it back on it would idle fine and after i gunned it it would do it again.
    any ideas?
    Oldschool Member
    Apr 2007
    i kinda have the same problem with my 4ac. mine wouldn't idle so i have to constanly keep the revs up manual, quick gets my foot tiring. well, my 4ac kept on dieing so i took it to the mechanic, he did this and that, fixed it for a few days and same old problem. i started to change different parts this and that and found that my leads were corroded... changed it and it works sweet, wasted all the money at the mechanic for nothing...
    i suggest u change your leads, spark plugs, and maybe ignition coil if u got the sapre money.
    hope that helps, thats my 2 cents
    Jarrod
    Magill
    cheers for that, ill give it a shot
    if its not that could it maybe be the fuel pump?
  1. smoke and idle problems?
    By nburr20 in forum Technical - Questions
    Last Post: 23rd September 2012, 05:16 PM
  2. 16v bigport IDLE problems
    By TOFU in forum Technical - Questions
    Last Post: 15th February 2011, 08:16 PM
  3. idle problems and wont coast under 3000rpm on 4age in ke70
    By imprezd in forum Technical - Questions
    Last Post: 5th June 2010, 01:37 AM
  4. 4ac Craby problems.. Choke+Idle
    By tc-rolla in forum Technical - Questions
    Last Post: 7th August 2009, 11:29 AM
  5. 4ac randomly cutting out at idle
    By Bobomacho in forum Technical - Questions
    Last Post: 25th February 2008, 10:07 AM
