Results 1 to 10 of 16
Thread: 4age dies when its hot
    Ok, I've tried a few different things now, and the common symptom of the problem is that it dies when it gets up to temp. It did develop a loping idle, but that has mostly gone away when I blocked off the Cold Start section on the bottom of the throttle.
    When it gets up to temp the revs start to go up and down very slightly, then as it gets hotter sometimes it will either just die quickly or other times it sort of trys to die, then catches it before it stalls, and then does it again and again until it dies totally.
    Once it has died it won't start again until it is cold.
    I have tried a different water temp sensor, different dizzy caps (new and old), the coil is new and the leads are new
    Any thoughts at all of what this problem could be would be great.
    Thanks
    Blake
    Old Post:
    Hi
    I have a freshly rebuilt 4age bigport in my car, it is running a standard computer, and a surge tank with a VL external fuel pump.
    I first started it the other night, once I sorted out all the little glitches (leads were in the wrong spot, etc.) it started fine, then after a bit it sounded like it was dropping a cylinder or something.
    I took it to the exhaust place to get an exhaust made, and it started fine there but they said that when they were checking for leaks it started to struggle then stalled.
    Before I left the exhaust place I bled the cooling system and after a while of running fine the idle started to lope sort of, then it started to struggle and after I turned it off I couldn't turn it back on again. When I got it towed home I found that the spark plugs were covered in fuel, so after drying them out it started fine.
    I then took it for a short drive and after a minute or two of running it started to feel like it was surging like when the old carb engine ran out of fuel. I turned around and it died as I was rolling back down my hill in neutral.
    Does anyone have any suggestions on what this might be?
    I've checked and its getting spark, the fuel rail is getting fuel
    Blake
    Injector/s maybe stuck open. Can you hear them clicking at idle if you can get it running again ? You should be able to feel them clicking open and closed too.
    yup injectors are clicking, which is also explained by it running fine up to temperature
    update: it dies when it gets up to temperature (about 85-90 degrees), idle starts sort of hunting, but not as bad as hunting, it'll idle fine, then drop off for a bit, then idle fine again, then drop off, and it gets worse up until the point that it dies.
    I did bleed the cooling system properly last night, any ideas?
    edit: does anyone know what effects a dodgy water temp sensor for the ECU would have?
    Jonathan
    Did you get the diagnostic codes from the ECU light?
    Do you have every single sensor and wire hooked up to the ECU?
    Do you have a 5th injector?
    <div class='quotetop'>QUOTE (Jonny Rochester @ Mar 21 2008, 02:02 PM) </div>code 3, and code 4
    I think 3 is because it hasn't been sparking, the plugs come out wet with fuel, and 4 is because i have a feeling that temp sensor is the problem
    Oxygen sensor isn't connected, and there is no cold start circuit, everything else is connected
    yes, I have a cold start injector
    EDIT: the dizzy is getting quite hot when it gets up to temperature, could that cause similar issues?
    No oxygen sensor wont help the situation but it wouldn't be this bad either. Dizzy getting hot is not normal, I can take mine for a thrash and its still cool with in reason.
    Whats the inside of the cap and dizzy look like when its cold and then when its hot ?
    I'm just throwing out ideas but maybe the dizzy getting hot is causing the pick up gap to be increased thus slowly loosing spark ?
    The inside of the dizzy looks the same hot or cold, I tried a different cap - no difference.
    First post edited as I have sort of found a common symptom of the problem.
    About to go swap the dizzy internals
    parrot
    What Jonny said. Check you have all the sensors connected up properly and they are setup properly.
    Look and follow the diagnostic charts methodically rather than guessing.
    The oxy sensor will not make any difference to your problem. Do you have a fuel pressure regulator on the fuel rail?
    Check your idle dashpot settings, TPS, the vacuums etc one at a time till you find it.
    Start with your codes and clear them when you resolve them.
    It is unlikely to be anything faulty, rather something you have left off, not wired properly or adjusted properly.
    Hi
    I do have a Fuel Reg, its just the standard one.
    I don't have a throttle dashpot, the TPS is set correctly, both air and water temp sensors are operating correctly, I have tried a different MAP sensor to no avail, and different pickups for the Dizzy
    Codes I have received were 3, 4 and 7
    7 was due to trying to start the car with the TPS unplugged, and 4 was due to trying to start the car with the temp sensor unplugged, 3 I cannot work out, using that diagnostic manual the wiring for the igniter checks out. (gets spark and correct voltage at the ECU)
    The only vacuum lines connected are one to the MAP sensor, one to the Fuel Reg and one to the charcoal canister, and these are all connected up correctly as per my previous thread. All others are blocked off.
    I am fairly confident that the loom has been done correctly as I had it totally stripped and laid out on the floor to confirm all of the wiring before I installed it into the car
    The other problem I have now discovered is that before it temps up and dies, it won't rev above 2500rpm. I only just discovered this last time I started it as I have never tried to rev it whilst it was stationary.
    Blake
    Elite rthy's Avatar
    Leo
    Tulla
    wats ur idle rpm when cold?
  1. 16v 4AGE dies warm then won't start again
    By Brokenships in forum Technical - Questions
    Last Post: 3rd May 2012, 10:06 AM
  2. 4AGE dies under 3000 rpm
    By grey_nomad in forum Technical - Questions
    Last Post: 7th June 2011, 11:10 PM
  3. 4age dies when hitting 6000rpm
    By Alexii in forum Technical - Questions
    Last Post: 18th September 2010, 11:16 AM
  4. FS AE86 turbo HOT HOT HOT!!!
    By 86 garage in forum Cars for Sale (Toyota Only)
    Last Post: 24th February 2008, 06:46 PM
  5. 4age farts and dies under throttle
    By Blood Child in forum Technical - Questions
    Last Post: 9th April 2007, 09:56 PM
