Results 1 to 8 of 8
Thread: how can i tell
    callum
    qld
    tully
    hey all. searched and couldnt find.
    how can i tell if my gze is bigport or smallport. see I'm in need of an intake manifold for turbs conv and I'm under the impression that if its bigport, ill need a bp manifold and vice versa. true?
    so yea how can i tell. not sure of the car it came from.
    your friendly neabourhood electrition. for cash jobs pm me!
    Veteran slide86's Avatar
    Huw
    Hills
    small port should have the oil drain on the back of the head. I'm pretty sure it still applies on GZE
    callum
    qld
    tully
    what will that look like? there is a bit of action going on out the back. not sure if its for oil or water though
    bigport = afm
    smallport = map
    can be changed etc.
    maybe a compression test?
    By far the easiest way to tell is to take off the inlet manifold. Bigport ports are not evenly spaced (1 2 . . 3 4) while smallport ports are (1 2 3 4).
    Or if you have an original wiring loom read the dates off any of the wires (they can be a bitch to find, but every wire should have a year printed on it somewhere).
    Ty
    ACT
    ACT
    I'm not 100% sure but I would have assumed you would be able to tell by comparing the runners. Here are the best pics I could find of a smallport and bigport inlet manifold...
    Elite rthy's Avatar
    Leo
    Tulla
    take a picture of the manifold and show us
    Veteran biggo's Avatar
    Nick
    Noosa
    pull it apart?
