Results 1 to 4 of 4
Thread: 4agc camshaft timing issues
    Apr 2006
    does the camshaft timing need to be altered when goin from injection to carbs?
    parrot
    It doesn't need to be, but you can alter the engine characteristics by doing so. Possibly for better or worse.
    But for a given set of cams, the manufacturer would specify particular duration irrespective of induction setup.
    Apr 2006
    <div class='quotetop'>QUOTE (parrot @ Mar 25 2008, 02:46 PM) </div>just found out that my valves are fucked in cylinder no 4, so not just an easy fix!
    Sep 2006
    I would say that with a stock motor, just line the cams up with the normal marks on the pulleys when you put the timing belt on. Same with either EFI or carbs.
  1. Camshaft timing expertise
    By timbo in forum Brisbane & QLD Events and Discussion
    Last Post: 5th December 2012, 09:45 PM
  2. Camshaft timing
    By timbo in forum Technical - Questions
    Last Post: 30th November 2012, 03:28 PM
  3. Camshaft Timing
    By Stain in forum Technical - Questions
    Last Post: 3rd February 2009, 12:50 PM
  4. 4AGC?
    By riojin in forum Technical - Questions
    Last Post: 26th November 2007, 01:30 PM
