Results 1 to 10 of 10
Thread: Fuel Overflow Problem - Any Suggestion???
    Oldschool Member
    Feb 2007
    Hi All,
    Been having a strange fuel overflow issue with the 86.
    Basically I fill her up like usual, drive her home and a couple of hours later I find a puddle of fuel on the ground.. Upon closer inspection the fuel is actually coming out of the fuel tank opening while the fuel cap is still locked in place. I removed the fuel cap while it was leaking and fuel gushed out (nothing crazy) and the fuel neck was full to the brim. Had to siphon out a good 500ml to get the fuel level down to the point where I couldn't see it. The car runs pretty well so, fuel supply isn't an issue. The 4AGE conversion was done in Feb and this overflow problem has come up 3 times.
    Just a little worried I'll blow myself up while driving her, and its also a bitch getting that fuel smell out of the cabin.
    Could it be pressure build up in the tank caused by something dodgy in the fuel system, or a crapy seal on the standard ADM fuel cap, it does wobble a little when its in the locked position. Could I be overfilling the tank, only ever get to one click at the bosser and I stop (only use 98RON). Driving me nuts trying to figure it out...
    Does anybody out there have any idea what could be causing the problem?????
    Bit of background on the car:
    > Engine converted to JDM 4AGE (Blue & Blacktop)
    > Inline fuel pump still using ADM lines with EFI hoses (fuel system conversion done by Toyospares in VIC)
    > No unleaded filler adapter fitted (was told it was fine as is and should pass Engineering)
    Any input would be appreciated
    Josh
    Elite rthy's Avatar
    Leo
    Tulla
    just a hunch but try unplugging your charcol canister and see if it still does it
    30kw club
    Veteran slide86's Avatar
    Huw
    Hills
    to much vapour pressure build up in the tank causing the seal to leak?
    maybe the vapour line on the tank is blocked, preventing the pressure from being released
    Elite rthy's Avatar
    Leo
    Tulla
    my thinking exactly, the vapor line goes to the charcoal canister you see
    30kw club
    i agree with sam, newer cars have pressure release valves on thier fuel caps. mine has rust
    on a side note, my car contiunes to 'hum' which comes out of the fuel cap, as the pressure from the fuel system creates
    some sort of vacuum and it hums away for a good 30 sec after the car is turned off... suggestions?
    Insert witty comment here....
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    i have this same problem, my boss at work has had a look and pointed the fact that a charcoal/carbon canister not being connected is causing the pressure in the tank to not be releived, causing it to build up and come out of my fuel cap, which was fucked, replaced fuel cap and it hasnt done it since, i gess its still building up a shit load of pressure but it only seems to happen to me on a hot day after ive filled up
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    DRFTR86 & FATKE.....DOSEING COROLLAS SINCE 2009
    Oldschool Member
    Feb 2007
    <div class='quotetop'>QUOTE (drftr86 @ Mar 26 2008, 10:54 PM) </div>Hey just wondering what fuel cap you replaced it with, can you buy after market fuel caps that are direct replacements for standard ADM items at your local repco or autobarn????
    Oldschool Member
    Feb 2007
    Thanks for the info guys. Did a bit more research today regarding the issue...and most likely it is a vapor line blockage causing the pressure build up in the tank. My shitty fuel cap seal just adds to the problem I see...
    Just wondering how I would check for blockage in the main line from the fuel tank to the Carbon Canister and also how I would get rid of any blockages..has anybody done something like this before??? Gonna check the Carbon Canister as well to see if it has shat itself.
    Don't really want to dispose of the carbon canister just in case I get probed by the EPA, and also because I still need to engineer the car...
    Thanks again for the input, much appreciated :2thumbs:
    Richard
    South Oakleigh
    since ur in melb, just ask bursons for a universal fuel cap, plus u get to unlock it with a key, just to add to the many keys you probably have like myself for the 86
    SQ ENGINEERING
    NCCE
  1. Replies: 4
    Last Post: 18th June 2012, 03:29 PM
  2. fuel problem
    By Shitbox in forum Technical - Questions
    Last Post: 8th June 2012, 06:28 PM
  3. Suggestion
    By Bozu in forum Bug Tracker
    Last Post: 25th February 2011, 10:30 AM
  4. Idle and fuel problem, running rich
    By capatown in forum Technical - Questions
    Last Post: 6th December 2010, 10:36 PM
  5. Fuel problem?
    By KE70 in forum Technical - Questions
    Last Post: 15th April 2009, 01:05 AM
