Results 1 to 7 of 7
Thread: What are the specs on std 4agze cams?
    Senior Member Dongaz's Avatar
    Cameron
    The Gap, Brisbane
    What are the specs on the std 4agze cams and how can I check what mine are? I'll get a pic up to see if mine are std or not.
    :teehee:
    Cameron
    The Gap, Brisbane
    Anyone got any ideas if it is a standard cam or not?
    Elite rthy's Avatar
    Leo
    Tulla
    ok measure the base circle and then the point of highest lift, after that look up a chart on the internet for 4age cam specs and see if what you have coresponds to the lift your meant to have
    Veteran slide86's Avatar
    Huw
    Hills
    aftermarket cams like toda and HKS usually have their brand name stamped on them.
    and they have the lift and duration on the end too
    but not always.....
    Veteran slydar's Avatar
    Dimitri
    cam specs are on club4ag
    78's
    Standard 4agze cams are 232 degrees duration and 7.1mm of lift. Thats all 4agze engines unless some one has swapped them over.
  1. Replies: 3
    Last Post: 31st October 2010, 04:08 AM
  2. 4ag Bigport cams, std higher lift ones...
    By mookschank in forum Car Parts For Sale
    Last Post: 13th December 2009, 07:43 PM
  3. Cams for a STD 4age 16v bigport
    By lowau in forum Technical - Questions
    Last Post: 11th June 2008, 11:45 AM
  4. HKS cams Specs...need info
    By jy086 in forum Technical - Questions
    Last Post: 2nd April 2008, 10:58 AM
  5. NEED 4AGZE STD PISTON AND OR BORE
    By orangechargd86 in forum Technical - Questions
    Last Post: 17th December 2006, 10:04 PM
