4age losing fuel supply round corners & when low fuel in tank...
AE86 has a standard ADM fuel tank and VL fuel pump.
If the tank is full or near full there is never a problem.
Example 1: at half full tank, round a sweeper bend, fuel supply gone (wouldn't be good for injectors), any throttle just does nothing, then give it a moment once straightened up, supply returns and all ok.
Example 2: approachin an low or Empty fuel tank, only gentle cornering can run out fo fuel supply, and even strong acceleration will run it out of fuell supply till reduction of throttle .
I'm sure there are baffles in an ADM fuel tank.
there is no surge tank fitted but i know there are other ae86 adm 4age that don't use a surge tank or a jdm fuel tank.
my best guess seems to be to do with fuel pickup from tank ?
long term problem, never found solution.
Someone else would have experienced/solved this problem with their converted 86 also?
whats been done so far:
metal fuel pump replaced
shifted the fuel pump to higher and lower position and different angle.
ive inspected the flow from the pump, but this wouldn't be the problem because when car has full tank, no problem.
Thanks for any advice.
