ill try and find the link of nissansilvia fair bit of those guys had tried it when they came out be back soon![]()
I was flicking thru my old (05) jaycar catalogue and and found the air/ fuel adjuster. It actually looks pretty cool, its looks to be just like a piggy back which intercepts the volts reading going from either map or airflow meter. Its a hell of alot cheaper than other name bracnd piggy back units which i would'nt bother with except this is bassically just a diy job which does the same job anywayz.
It has real time mapping, 128 load points.
Do you think there would be any gains from this unit?
ae71 parts for sale stripping 3xae71's and a ke70
cool thnx dude, i'll have a search now to.
the sites down so ill try a little later on
anyone find anything on it?
they do i was lookng at them yesterday...
I did a fair bit or research on it and found that you can only use it if you have air flow meter. To be honest i wouldnt even bother, i bought the jay car air/fuel display and its so inaccurate its not funny, then again its only cheap and was never designed for tuning. So i doubt the air/fuel adjuster will be super accurate.
Saying that, half the fun is in building it.
If you really wanna adjust fuel mixtures go for a 'real' piggy back unit or even better full aftermarket ecu. :2thumbs:
<div class='quotetop'>QUOTE (eightsixboy @ Sep 12 2008, 12:45 PM) </div>
i agree BUT!!
it is basically an SAFC without the price tag and better! my car runs afm so i can use it...
will let you guys know results when i put it in![]()
