Results 1 to 10 of 16
Thread: Engine makes screeching sound
    Scott
    South Brisbane
    Curious if anyone know what might cause this.
    When the cylinder head cover outlet is connected to the intake manifold (vacuum) a whining sound starts up.
    To counter this from occurring i installed a mini air filter for the cylinder head outlet which stopped the whining sound.
    The sound only occurs when the cylinder head outlet is connected to vacuum. Interesting when the engine is turne off; the sound slows/or fades out, suggesting that the sound is a result of a moving part.
    Does any know what is the cause of this.
    Site Supporter Javal's Avatar
    Josho
    You have a small demon in your intake manifold. Whenever you connect the vaccum line to your rocker cover, that screeching is the sound of the demon trying to suck out the 4AGE's machine soul.
    Scott
    South Brisbane
    Ah ok, I though it could have been a 'whining bitch'......
    Any advances on supernatural beings in my engine being awoken by vacuum?
    Jul 2009
    Adam
    Gold Coast
    spun a big end
    Oldschool Member
    Mar 2007
    do u have a pcv valve in there
    Scott
    South Brisbane
    I didn't think 16v's came with a PCV. I didn't put one in so, no it doesn't have a PCV.
    Veteran slide86's Avatar
    Huw
    Hills
    its definetly a vacumn leak....
    i would think that there is a leak in the throttle body gasket or something similar.
    when you disconnect the hose to the manifold, there is an easier path for the air to go into the engine, so the vacumn leak is not evident.
    but when you reconnect the hose, air will try to get into the engine anyway it can....so the vacumn leak becomes evident.
    what you should do is leave the hose connected, so the noise is evident, then spray wd40 around any areas that could have a vacumn leak ie throttle body gasket, inlet manifold gasket.
    if the revs pickup or the noise goes away when you spray in that area, then you have found the problem
    (the sound fading out would be an indication that the enigne is sucking in air as it stops turning)
    Senior Member shakes's Avatar
    Simon
    Vic
    Melb
    can also be the vaccuum being dragged around your TB. have had this before in other car's
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    i had the same problem, thought it was my pcv, so ripped the inlet manifold off and put quads on it, but 2nd what slide86 says, it was a vac leak on mine but i never could find it b4 i did my conversion, but i used to spray brake kleen into the pcv whilst it was making noise and would stop for a while, and reoccur when it got really hot
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    Jul 2007
    <div class='quotetop'>QUOTE (race4ages @ Apr 5 2008, 05:58 PM) </div>You might find one of your idle up solenoids has its air lines back to front. I had this once on an air con idle up and it made the noise. Swappd it around and hey presto - silent. They were only made to work (competently) one way.
  1. What Makes You Happy?
    By shift_rook in forum Offtopic Discussions
    Last Post: 5th December 2010, 02:30 AM
  2. who makes?
    By silver styler in forum Technical - Questions
    Last Post: 26th November 2006, 02:04 PM
  3. my mate thinks cam gears makes the car sound better ??
    By mr2drift in forum Technical - Questions
    Last Post: 12th June 2006, 10:41 PM
  4. who makes these and how much?
    Last Post: 13th May 2006, 10:52 PM
  5. sound from engine when it is cold?
    By Ksevn-T in forum Technical - Questions
    Last Post: 12th May 2006, 08:35 PM
