Results 1 to 10 of 12
Thread: WTB 3sgte RWD conversion parts
    Will
    San Remo
    Hi All,
    I'm looking for all the parts needed to convert a 3sgte Gen 3 ST205 GT4 engine to RWD. I already have the bellhousing and engine.
    Located in Sydney. Willing to pay for post.
    Thanks in advance for the help
    Will
    Will
    San Remo
    Bump
    Veteran slydar's Avatar
    Dimitri
    youre going to have to make, or have made, most of them the parts you need. and what they end up looking like is going to depend on what car you put them in.
    also to you need to let people know which version of engine you have, as they run all different sumps, exhausts and intakes ect.
    for flywheel, you want to get yourself an altezza one.
    or also there is an ebay store now (japanese, ships to au) that has them quite cheaply if you search altezza itll come up.
    that will get the motor bolted to the transmission, and in to the car, from there the rest is basically custom.
    78's
    Will
    San Remo
    Thanks again for the helpful advice Slydar. I will find out what version of the engine it is.
    Will
    Will
    San Remo
    ok, so i have been told that the engine is a Gen 3 ST205 GT4 engine. Its going into a 69 RT40 toyota corona.
    werm
    pls mind my sillyness.. but..
    if its the 4wd tranny.. can't u weld up the diff and disengage the front drives... that'll leave the rears only ??
    just wondering.... :offtopic:
    Jay
    no you don't use the 4wd transmission , you us a another bellhosing, from memory a 2s one onf 3sge and mate it up with a rwd gear box
    Rust is a way of life
    Site Supporter Javal's Avatar
    Josho
    <div class='quotetop'>QUOTE (werm @ Apr 21 2008, 02:23 PM) </div>no
    The motor is mounted in-line, not transversely. The AWD gearbox is binned. you use a traditional RWD style layout and gearbox.
    <div class='quotetop'>QUOTE (hachirusto @ Apr 21 2008, 09:05 PM) </div>and no.
    you use a 3Y bellhousing (requires only minor modification to fit) or one from Dellow / Niteparts.
    If you use the 2S bellhousing you can only use the crappy borg warner box. The 3Y /Dellow/Niteparts bellhousing allows you to use a W5x gearbox.
    That said, i suppose you could fill / drill and then space out / shorten the 2S bellhousing to accept a W5x box.
    werm
    i was only thinking this becos something like that was done on a gc8 used in one of the best motoring Hotversions. i think it was for the project D or something and in fact they came up with conversion kit to replace the welding. not too sure of the specifics..
    thanks for the clarification javal :2thumbs:
    Josho
    No problems buddy.
    The reason why they would have fiddled with the GC8 gearbox instead of binning it, is that it is once again a different layout.
    The motor and gearbox lay in-line, with driveshafts poking out either side.... to put it very simply.
  1. Jdm 4age Rwd Conversion Parts
    Last Post: 24th June 2014, 12:09 AM
  2. 4age Rwd Conversion Parts For Sale
    Last Post: 11th December 2012, 10:12 AM
  3. AE86 Assorted Parts, 3sgte to RWD Parts
    By medwin46 in forum Car Parts For Sale
    Last Post: 3rd March 2008, 02:53 PM
  4. 20v rwd conversion parts
    By hillclimb86 in forum General Topics (No Technical Questions)
    Last Post: 14th November 2006, 02:50 PM
