set the timing correctly adjust the valve clearances get new leads, plugs, dizzy cap, rotor button, points and condenser, also open up the exhaust and cut away the stock air box and if you really want put a 3k head on and twin webers but don't wast you're time with a 4k its definitely not worth it get a new motor. :2thumbs:
