Results 1 to 4 of 4
Thread: ae71 hydrolic cluth into a ke70
    Junior Member DRF17's Avatar
    hey, ive just pulled out the clutch and brake prdal box in my ke (wot a prick that was) plus half my dash, and seemed to run into a few problems with the master cylinder as there are no holes obviously i have to drill for them but it looks like the brake booster may be in the way, anyone ran into this problem and over come it? or just any general tips would be greatly appreciated
    cheers, Blake
    Senior Member Medicine_Man's Avatar
    Justin
    North
    seek and ye shall find..
    Why hesitate when you can accelerate???
    Yellow 1984 KE70 Corolla, 1.3L 4K-C, Tighe 104 Cam, Electronic Dizzy, Dellorto DHLA40s,
    4-1 Hurricane Extractors, 2" Exhaust System, 5 Speed, Factory Mags, Towbar, 33 RWKW Last dyno.
    Site Supporter Javal's Avatar
    Josho
    errr........
    yes you'll have to drill holes, because the KE obviously didn't come with a hydraulic clutch.
    take some measurements. then measure again. then drill.
    there will be plenty of room, it will clear the brake booster.
    I assume you're using an AE71 pedalbox to replace your KE70 one.
    What i recommend you do is take all your measurements on the inside of the car so the pin for the master will line up perfectly with the part where it attaches to the pedal. drill small guide holes, THEN drill your big holes from outside the car.
    cheers guys, yeah had a bit of a search but didnt work 4 me
    thanks lads, Blake
  1. ae71 hydrolic clutch pedal box
    By maners in forum Cars or Parts Wanted
    Last Post: 15th May 2011, 05:28 PM
  2. Ke70 manual cable pedalbox.. NOT hydrolic!!
    By corey70 in forum Cars or Parts Wanted
    Last Post: 6th March 2010, 11:48 PM
  3. ke55 wanna convert to hydrolic clutch IDEAS
    By ae86-13b in forum Technical - Questions
    Last Post: 19th November 2009, 10:08 AM
  4. hydrolic handbrakes whats best?
    By pen15 in forum Technical - Questions
    Last Post: 5th October 2009, 06:05 PM
  5. WTB AE71 (hydrolic) manual pedal box!!
    Last Post: 16th February 2009, 08:22 PM
