Results 1 to 6 of 6
Thread: cusco camber tops?
    Jim
    West
    Hey people..
    what shocks are compatible to fit cusco camber tops with standard adm struts as ive found that koni yellows do not fit??
    Daniel
    GC Hinterland
    <div class='quotetop'>QUOTE (snake @ Apr 18 2008, 01:35 PM) </div>i had an engineering firm make me up some bolts to fit the koni yellows.
    Jim
    West
    oh really?
    how much did that set you back??
    Daniel
    GC Hinterland
    bit pricey at $50 but i wanted them asap.
    Jim
    West
    <div class='quotetop'>QUOTE (munki @ Apr 18 2008, 03:55 PM) </div>meh .... not too bad beats getting new pair of front shoks!
    Jonathan
    Most of the time the spacers/nuts that go between the strut top and coilover spring hat have to be custom made. $50 is a resonable fee to sort this out.
    The best setups have either the spacer or spring tophat located on the shocks 2 flat bits near the thread. This way you can hold onto something when you do the shock nut up. I have developled a spacer that locates in the shock, and has flats ground onto it for a spanner. This way you can use 2 spanners and do the shock nut up as tight as you like. No need for a rattle gun.
  1. Cusco Camber Tops
    By skizzamods in forum Car Parts For Sale
    Last Post: 7th April 2012, 01:02 PM
  2. Cusco Camber Tops NEW
    By 86adz in forum Car Parts For Sale
    Last Post: 30th November 2009, 09:08 PM
  3. cusco camber tops
    By 350hp4agte in forum Technical - Questions
    Last Post: 28th September 2007, 02:18 AM
  4. help with cusco camber tops
    By deanoo in forum Technical - Questions
    Last Post: 3rd December 2006, 02:27 AM
