Results 1 to 10 of 16
Thread: ra40 axles into t-series
    Senior Member eightsixboy's Avatar
    Paul
    East
    I have bought a diff which i think is either from a jdm ae86 or maybe a te series corolla, anywayz it came with axles and centre from a ra40 and when i bolt the axle up on the rhs the bearing will almost seize, i put the same axle in the lhs and its fine. They have both been shaved down but one has been shaved more than the other and its actually been shaved on a angle lol.
    I have replcaced both bearings, checked in the housings for any obstructions and it all looks good.
    I have been told that i will have to grind 10mm of the original length of the axles for it to fit cause the ra40 diff's were like 20mm longer than other t-series.
    It makes sense that the axle would have to be shorter on the pinion side of the diff, but how much should i take of, i don't know what the original length of the shafts were.
    Has anyone has had any experience with this before? Or maybe used ra40 axles in a ae86 housing?
    Cheers.
    Yes, been discussed a lot.
    10mm off each axle using RA40, RA60, RT132 axles in TE72 housing. Worked a treat for the last 4 years or so.
    Ferny Grove
    i concur
    10mm of length removed from both axles = success!!
    Paul
    East
    hey i also found out that you have to lenghthen the splines or it'll bottom out. :2thumbs:
    Really???
    I've never run into that problem and I've had probably 10 axles and 5 centres through my T18 housing.
    Could it possibly be an RA23/28 housing?
    Oldschool Member
    Mar 2008
    with the T18 housing and RA40 axles 8mm is sufficient, and no, you do NOT need to lengthen the splines....
    Oldschool Member
    Mar 2008
    Shaving the axles doesn't alter the original track of the axles? It just lets the axles fit into the lsd?
    Oldschool Member
    Mar 2008
    correct....the ra40 housing is wider, so the axle is shorten to suit the narrower housing...
    Paul
    East
    i actually had to lenghten the splines on the rh axle cause the wheel bearing would seize when i did up the bolts :huh: . I checked everything out, measured and re-measured everything and i had to lengthen the splines about 1mm so it wouldn't bottom out in the diff. When i mean lenghten i just cut a ridge were the splines ended so it would slide further into the diff.
    After i did that it was fine, although there is a bees dick of endfloat, were as the lhs axle is completly solid.
    Maybe i do have a ra28 housing? But that would'nt bolt in anyway cause arnt the mounts for the arms in different places? I was told the it had a ra40 centre and axles.
    If you cut a groove around the end of the splines I'd be worried. This is exactly where the axle breaks normally. Plus you will have cut through the outer heat treated layer, which helps with its strength.
  1. WTB RA40 axles (nsw)
    By Dexter in forum Cars or Parts Wanted
    Last Post: 24th May 2012, 10:51 PM
  2. Ra40 axles in zenki t series diff
    By Sprintn in forum Technical - Questions
    Last Post: 11th August 2011, 10:04 PM
  3. t series centre. t18 ra40 etc
    By phil in forum Cars or Parts Wanted
    Last Post: 4th August 2009, 04:29 AM
  4. t-series axles or diffs. either ra40, ra60, t18 etc...
    Last Post: 13th April 2009, 12:42 AM
  5. t series from ra60 or ra40.
    By Rakurai in forum Cars or Parts Wanted
    Last Post: 22nd May 2008, 11:31 PM
