Hey guys,
if i swap the 4a bellhousing onto the t18 gearbox and use the correct tailshaft will everything else work in my ae71?
Thanks
Hey guys,
Thanks
T18 in the build
does the clutch fit the front splines on the input shaft and does your tailshaft fit the splines on the output shaft ? eg number of teeth
Yes, I think so.
Should do, may need to use a T-18 full tailshaft? I can't remember, it's been too long.
The clutch is on the drivers side too, so use the clutch hard line from the T-18 also.
bah too much effort. just gonna get a box from pick a part
Thanks guys
T18 in the build
Sorry to drag up an oldish thread, but I have just busted the t50 in my ae71, but I know where there is a t18 with a box still in it. What tail shaft set up do i need to install this box?
Will the t18 tail shaft front half bolt to the ae71 rear half? Or wil the t18 box happily mate to the ae71 tail shaft regardless?
Any help would be appreciated, cheers
Driver of the yellow ae86
http://www.ae86drivingclub.com.au/fo...hlight=custard
AE71 tailshaft is one piece so you are going to have problems there and the AE71 tailshaft wont go into the t18 box either. You'll probably need to go to an S or T series diff and the corresponding rear half tailshaft in order to make it a bolt in affair.
<div class='quotetop'>QUOTE (Golberg @ Jun 22 2008, 11:07 PM) </div>AE71(4a) tailshafts are two piece, KE70 (4K) shafts are one piece.
Maybe you will need the T18 front shaft, thats only if T18s have two piece items as well.
<div class='quotetop'>QUOTE (lowau @ Jun 23 2008, 04:22 PM) </div>I think you'll find most AE71's had a 1 piece. They have a centre bearing and a middle uni joint but you can't physically unbolt two the halfs from each other like you can in an AE86 or TE72. Both my manual and auto AE71's had this arrangement.
That was my fear - I have the t series here, but i don't have the cash to install the lsd before I put it in, or the lower ratio. Bummer
Thanks for your help mate, I will keep an eye out for the right box then.
