Results 1 to 10 of 13
Thread: T18 T-50 into AE71
    Calvin
    Kilsyth
    Hey guys,
    if i swap the 4a bellhousing onto the t18 gearbox and use the correct tailshaft will everything else work in my ae71?
    Thanks
    T18 in the build
    N.T. Darwin
    Anula
    does the clutch fit the front splines on the input shaft and does your tailshaft fit the splines on the output shaft ? eg number of teeth
    Jonathan
    Yes, I think so.
    Site Supporter Javal's Avatar
    Josho
    Should do, may need to use a T-18 full tailshaft? I can't remember, it's been too long.
    The clutch is on the drivers side too, so use the clutch hard line from the T-18 also.
    Calvin
    Kilsyth
    bah too much effort. just gonna get a box from pick a part
    Thanks guys
    T18 in the build
    Nat
    Newcastle
    Sorry to drag up an oldish thread, but I have just busted the t50 in my ae71, but I know where there is a t18 with a box still in it. What tail shaft set up do i need to install this box?
    Will the t18 tail shaft front half bolt to the ae71 rear half? Or wil the t18 box happily mate to the ae71 tail shaft regardless?
    Any help would be appreciated, cheers
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    AE71 tailshaft is one piece so you are going to have problems there and the AE71 tailshaft wont go into the t18 box either. You'll probably need to go to an S or T series diff and the corresponding rear half tailshaft in order to make it a bolt in affair.
    Nat
    Newcastle
    That was my fear - I have the t series here, but i don't have the cash to install the lsd before I put it in, or the lower ratio. Bummer
    Thanks for your help mate, I will keep an eye out for the right box then.
    Aaron
    In the Mountains
    AJPS has a 4A teefiddy instock
    Oldschool Member
    Aug 2007
    <div class='quotetop'>QUOTE (Golberg @ Jun 22 2008, 11:07 PM) </div>AE71(4a) tailshafts are two piece, KE70 (4K) shafts are one piece.
    Maybe you will need the T18 front shaft, thats only if T18s have two piece items as well.
  1. Replies: 1
    Last Post: 11th March 2012, 09:08 PM
  2. Replies: 9
    Last Post: 13th May 2011, 08:31 AM
  3. i need a ae71 T-50 Bellhousing
    By aaronke70 in forum Cars or Parts Wanted
    Last Post: 20th October 2010, 09:14 PM
  4. Replies: 7
    Last Post: 5th April 2010, 10:11 PM
  5. FS: t18 tailshaft, 3t, T-50, and T-28 turbo
    By TOY3TG in forum Car Parts For Sale
    Last Post: 14th May 2007, 01:00 AM
