Results 1 to 6 of 6
Thread: Brakes/ brake booster rooted????
    Feb 2008
    hi all i recently smashed my ae71 anyway i got the chassi pulled out and they replaced the solid brake line to the front left as it was snapped any who the smash repairer sent it to a brake place to get the stuff done and when i picked it up yesterday arvo you couldn't brake at all it would go all the way to the floor and you would get hardly any breaking so i headed home looked at the fluid level cause the light was on so i filled it back up and hoped that would fix it but it didn't there is a leak somewhere in the engine bay cause i got up this morning to find all my brake fluid on the ground under the car <_< i have no idea where it is leaking from and it's annoying as hell i hate it when shit doesn't get done properly anyway where should i look for the leak i know it is somewhere near the master cyl but not sure where also how would i go about bleeding them myself??
    Jonathan
    First problem is the leak. Blead it after that.
    Where the master cylinder is bolted to the booster, is it leaking there? If so, the master has to come off and be pulled apart.
    Feb 2008
    yeah it seems like it is leaking from around where it joins there is a little amount of break fluid around the join and some has leaked not sure when though but it has leaked down to the bottom of the master cyl along the outside yesterday when i got home and pumped em i got a sound like a spray bottle coming from that area but i couldn't see it guessin that was probly air lol and i could see it misting the brake fluid into the air but couldn't see where it came from.
    Jonathan
    Replace or rebuild master cylinder.
    Feb 2008
    hmm how would i go about rebuilding it would it be worth the time or would it be faster to just replace it if so what $$ are we talking?
    Jonathan
    Cheapest for you is to just use another used one that is good, and keep the old one for later.
    Or take it apart and buy a seal kit for it. You have to inspect the bore and make sure its ok. I think they are aluminium with a stainless steel liner. Not sure if its a good idea to hone them or not. With the old cast iron ones, people used to home them alot and replace the seals. These days, its more comon just to buy a new unit.
  1. Vacuum Booster-less Brakes
    By PRIMRK in forum Technical - Questions
    Last Post: 15th December 2010, 10:33 PM
  2. BRake Lines - Brake Booster One-Way valve
    By bigm in forum Cars or Parts Wanted
    Last Post: 29th January 2010, 06:56 AM
  3. brake booster or no booster?
    By slippry in forum Technical - Questions
    Last Post: 29th April 2008, 11:41 AM
  4. Replies: 10
    Last Post: 11th December 2007, 11:16 PM
