Hey guys, just have a few questions.
Guys with AJPS coil-overs, how low can you get the front and still have enough shock travel? (Ie: how far is the locking ring away from the end of the threaded sleeve). I've got 7kg springs and agx shocks.
Are ADM and JDM calipers the same. Do both have the 2022 number stamped on? If so then how do you tell the difference?
Guys with rb74 pads, when you first put them in and started bedding them in, did they smoke a bit?
I've got 6kg 230mm AJPS springs in the rear, how much should I chop to drop 20mm (Stupid question and I know I should trial and error, just thought I'd ask before I fuck them)
I know there's a thread, but what's the best Toe, Castor and Camber settings for a streeter that see's a fair bit of cornering.
I have a rough idea of them : -2.5 - 3.0 Camber
0.5 - 1mm Toe out each side
+3 Castor (Heard that's what stock arms max out to)
I think that's about all.
Thanks guys.
-Roy
