Results 1 to 9 of 9
Thread: WTB Small port fuel rail
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    any body got one with a reg, lemme know
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    Ok
    Seamus
    Milton
    i have a fuel rail with 'blue' injectors in it. is that the one you're after?
    ^ Clicky clicky!
    Richard
    South Oakleigh
    not sure mate, someone care to clarify, i have one atm but i need to block to cold start off and ive put on the magnum metal bonding shiton but it aint working, it has green injectors,ie. ae92
    SQ ENGINEERING
    NCCE
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    <div class='quotetop'>QUOTE (drftr86 @ Apr 28 2008, 08:40 PM) </div>The 2 small port fuel rails I've had always had a green connector plug on the injectors and the one bigport one I had used black colored connectors, not sure if that helps.
    Richard
    South Oakleigh
    perhaps 7OXIN post up a pic, need to see if the spacing between injectors is correct, it may be a gze one but i could just put my injectors and reg back on it, post a pic please
    SQ ENGINEERING
    NCCE
    Ok
    Seamus
    Milton
    yeah man easier done than said.
    this is the exact one I have, just took the pic now.
    spacing between injectors, as well as the bolt-holes should be exactly the same regardless of which 16V it is. the only thing that *might* be different is the stuff on top of the rail (reg, fuel feed etc)
    ^ Clicky clicky!
    Richard
    South Oakleigh
    looks sweet toxin, just need to be 100% sure that the spacing between injectors is even as a bigport fuel rail has injectors 2 & 3 spaced further apart
    can see difference in spacing here
    SQ ENGINEERING
    NCCE
    Ok
    Seamus
    Milton
    ahhh i see what you mean. yep i guess mine is not the right one, good try anyway haha
    ^ Clicky clicky!
    Richard
    South Oakleigh
    thanks anyway, any one else
    SQ ENGINEERING
    NCCE
  1. Wanted, small port N/A fuel rail
    By Prime86 in forum Perth & WA Events and Discussion
    Last Post: 15th July 2012, 11:48 PM
  2. Replies: 5
    Last Post: 4th November 2011, 12:59 PM
  3. Small port wiring Loom. injector rail and injectors
    By KE70briskev in forum Cars or Parts Wanted
    Last Post: 7th January 2008, 04:22 PM
  4. 4age small port fuel rail
    By loc33e in forum Cars or Parts Wanted
    Last Post: 18th December 2007, 05:45 PM
  5. small port fuel rail
    By drftr86 in forum Cars or Parts Wanted
    Last Post: 20th November 2007, 12:08 PM
