i have a fuel rail with 'blue' injectors in it. is that the one you're after?
any body got one with a reg, lemme know
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
DRFTR86 & FATKE.....DOSEING COROLLAS SINCE 2009
not sure mate, someone care to clarify, i have one atm but i need to block to cold start off and ive put on the magnum metal bonding shiton but it aint working, it has green injectors,ie. ae92
SQ ENGINEERING
NCCE
<div class='quotetop'>QUOTE (drftr86 @ Apr 28 2008, 08:40 PM) </div>The 2 small port fuel rails I've had always had a green connector plug on the injectors and the one bigport one I had used black colored connectors, not sure if that helps.
perhaps 7OXIN post up a pic, need to see if the spacing between injectors is correct, it may be a gze one but i could just put my injectors and reg back on it, post a pic please
SQ ENGINEERING
NCCE
yeah man easier done than said.
this is the exact one I have, just took the pic now.
spacing between injectors, as well as the bolt-holes should be exactly the same regardless of which 16V it is. the only thing that *might* be different is the stuff on top of the rail (reg, fuel feed etc)
looks sweet toxin, just need to be 100% sure that the spacing between injectors is even as a bigport fuel rail has injectors 2 & 3 spaced further apart
can see difference in spacing here
SQ ENGINEERING
NCCE
thanks anyway, any one else
SQ ENGINEERING
NCCE
