Results 1 to 10 of 12
Thread: mini/full-spools
    riojin
    just wanna know the difference between a mini and a full spool and weather they are practical or not.
    i like the idea of these more than a welded diff because its less dodgey.
    where are these available from or how much would they cost to get made for an e or f series diff?
    Veteran biggo's Avatar
    Nick
    Noosa
    practicle, no they arnt
    id rather weldies because they atleast offer some sort of give on the axles
    riojin
    by practical i meant will i be snapping axels easily like i would with a locker. i don't care if its uncomfortable to daily drive, i care about having to replace axels every few weeks because I'm snapping them all the time.
    Jul 2007
    it does the same thing as a weldy :blink:
    biggo, why would you say that a weldy would have more give than a spool? :wacko:
    a minispool replaces the spider gears inside the diff with a solid piece of steel with splines in it for the axles
    a full spool replaces the whole centre, bolt your crownwheel on & slide axles in
    if you are breaking axles with a weldy you will break axles with a minispool or spool
    theyre mainly for diffs that arent easy to weld or break spider gears
    Dave
    <div class='quotetop'>QUOTE (200BSX @ Apr 30 2008, 04:07 PM) </div>agreed!!
    biggo..whatchoo on about willis, both are bad for axels
    both are illegal, and both are a nuissence to drive.
    they are essentially the same as a welded diff, cept you don't weld, you just replace the whole centre with a new one, that is already "locked"
    i would probably buy one over a welded diff, since then you don't have to worry about dodgy welding/welds snapping.
    - Blaise Pascal
    Paul
    Queensland
    Camp Hill
    <div class='quotetop'>QUOTE (200BSX @ Apr 30 2008, 04:07 PM) </div>I believe you did, but just to reiterate..
    Jul 2007
    and you don't have to worry about little weld balls going into your bearings and munching them
    and you can take the spool out and replace with LSD if youre that way inclined
    with welding once its welded its always welded, destroyed
    where do you get minispools for S and T series? anyone know?
    Jonathan
    I have found full spools for T series diff from time to time, both steel or aluminium. Some place in USA makes them, as a T series diff is used for those funny little cart/car things. (Like Aussie Legends, but in USA) A full spool is desirable over a normal welded diff or a mini spool because it is lighter.
    But in a full size car, the T series axles snap too often. So for a normal car with a T series, a 2-way LSD is the way to go. All the benifits of a locker, but nicer to drive and no snapped axles.
    Jul 2007
    Ah but $$$ lol
    if i wanted to spend $$$ i would have a JZX100
    Russ
    Congupna
    mini full and weldys are all exactely the same to drive with because they are all 100% locked
    minispool slots inside stock centre reaplcing spiders and carrier
    full spool replaces the whole centre, you bolt your crown to it and away you go
  1. mini spool
    By 96sonataBro in forum Technical - Questions
    Last Post: 21st November 2012, 10:32 PM
  2. Hilux mini/full spools
    Last Post: 23rd February 2010, 11:55 AM
  3. Mini Spools?!
    By choonga in forum Technical - Questions
    Last Post: 2nd October 2007, 06:42 PM
  4. New Mini concept
    By flamingheads in forum General Topics (No Technical Questions)
    Last Post: 20th May 2007, 11:12 PM
  5. mini ferrari
    By 20v kid in forum Offtopic Discussions
    Last Post: 2nd May 2007, 08:38 PM
