Results 1 to 10 of 18
Thread: 9AGE discussion
    riojin
    Question
    <div class='quotetop'>QUOTE </div>
    sounds interesting. anyone have any more infomation?
    Veteran biggo's Avatar
    Nick
    Noosa
    bah! seems like the hard way to get 2lts
    this or 3sge?
    *edit* 1/2zzfe and for that matter 2zzge's arnt exactly disposable motors in 2008, you have given me something to search for on the intehwebs
    riojin
    well if you don't mind the difference it will put on the weight balance on your car then a 3sge is the way to go.
    i found this
    Sameul
    Bulleen
    Sounds like a lot of trouble to go through to get a 2 litre xAGE
    Would be a bit of a torque monster though
    3SGE would be a bit simpler... And probably be made to rev harder and hold together longer at the end of the day?
    Intersting technique though
    I still think a 22R-E with some form of twincam head, bottom end balancing and a decent huffer would be a winner though God i'd love to do an all CNC billet head
    Senior Member kaibeecee's Avatar
    Pete
    you can see the benefit of using a 7a block, as you wouldn't have any of the mounting issues that a 3s has. just straight in, and mounted
    Andrew
    3sge weighs 18 kg more than a 4age. If you move the battery to the rear, it will iron out the weight difference. Also, i believe that 5kg of that 18 is in the huge cast iron alternator mount the 3sge's run.
    Veteran slydar's Avatar
    Dimitri
    its an interesting idea i heard about ages ago. but its by no means practical at all.
    there was a written off sportivo like over a year ago at eumundi auto wreckers which had the engine damaged, tried to get them to sell me the crank but nothing cam of it.
    its just another one of those things you see on the net a bit which is really a u.s based idea, and doesnt really make sense in OZ. kinda like those dunga F20s..
    78's
    Elite rthy's Avatar
    Leo
    Tulla
    sounds like all bullshit to me, for a start "anything past 83mm will require the block to have pressed in liner sleeves" even 83mm is un-recomended from engine builders and sleeves or not the gap between cylenders would be seriously small.
    I want to know has anyone actually ever done this?
    Jonathan
    Just a note: 2ZZ-GE has a different stroke to a 1ZZ-FE.
    Jan 2008
    what my two of my friends had to say about that 9age info
    <div class='quotetop'>QUOTE </div><div class='quotetop'>QUOTE </div>So the main argument here is that anything can be done, but is it worth it?
  1. 4agze Discussion
    By Mickey H in forum Technical - Questions
    Last Post: 20th January 2009, 03:30 AM
  2. 4AGZE discussion
    By Gilly in forum Technical - Questions
    Last Post: 30th September 2008, 01:16 AM
