<div class='quotetop'>QUOTE (lowau @ May 2 2008, 05:05 PM) </div>Why would you want to run dual swaybars?????????????????????????????????????????? ?
I have similar swaybars in mine, got them from AJPS. Makes the car sit nice and flat.
I have used the search function and found out that you can use AE86 swaybars on *e7*'s,
but why does whiteline have different part numbers for both front bars, only the rears are the same part number?
I have a KE70 and was thinking of going the 24mm up front and 18mm rear, depends on the price ill look at the adjustables.
Recently a mate who has a R31 told me about those guys were doing to their cars with the rear swaybar:
Look at "Dual rear sway bars" further down the page here:
I was wondering if anyone has done this to a rolla?
The track bus -> http://www.ae86drivingclub.com.au/fo...ead.php?t=2725
I used:
BTF35Z
BTR25R
Thats a 24mm adjustable front and 18mm non-adjustable rear.
<div class='quotetop'>QUOTE (pope @ May 2 2008, 05:20 PM) </div>Becuase I stripped an AE71 and have a spare swaybar, haha
If it can be done and works well, its a cheap mod compared to buying an aftermarket one.
Anyone done this? I read somewhere that people have done this, just can find it now.
<div class='quotetop'>QUOTE (ae71neo @ May 2 2008, 05:22 PM) </div>Same here, works a treat.
Double sway bars were good in the 80's when you couldn't physically buy an upgraded one for your car, now you can save the hassle and get a proper one thats been tested and comes with stiffer bushes.
i was running duel rear swaybars for ages. very stiff, and free!
i only did it because i had 2 sitting there.
then when i upgraded to a bigger diff i could not fit the 2. so went whiteline non-adjustable 18mm.
i also have a spare laying here and have thought about mounting it as a dual setup.
thought it would sit too low and would cause TOO much oversteer?
Ohh well, I'm gonna try it in a couple of months time anyway just to see how it is.
Thanks for your input.
