Results 1 to 8 of 8
Thread: Crank pulley issue?
    Jul 2010
    james
    Bentley
    Hi guys,
    pretty new to the car and hasn't been driven much. It's my ae86 with a 4age rwd. When looking into the engine bay i noticed that the crankshaft pulley wasn't in line with the waterpump pulley and the alternator. The runs OK, pretty slow and i think it may be a large issue.
    Does it need adjusting or has the previous owner just put on a different kind?
    Any help would be appreciated.
    Jonathan
    Not good. It seams the previous owner has mis-matched some parts.
    Maybe you have a RWD waterpump, with a FWD waterpump pulley. In this case, you need to buy a RWD waterpump pulley either new from Toyota, or secondhand. The part number to buy this is in the Tech Articles section.
    There are other posabilies. It is probably due to mixing FWD and RWD parts.
    Veteran Nikkojoe's Avatar
    Tom
    <div class='quotetop'>QUOTE (Jonny Rochester @ May 2 2008, 06:45 PM) </div>I think its actually just a fwd crank pulley on a rwd engine. Post a pic of it if you can. Kaizen Garage have a second hand crank pulley for sale if you need one
    Eddie
    Crank pulleys are interchangeable between fwd and rwd. It'll be either the waterpump itself OR the pulley on the waterpump.
    You need to use the shallower pulley on the shorter pump (fwd setup) or the deep pulley on the longer pump for the rwd. Try not to use a clutch fan on the fwd setup as it lacks the extra bearing to cope with the load.
    Eddie.
    Jul 2010
    james
    Bentley
    <div class='quotetop'>QUOTE (Big T @ May 3 2008, 10:58 PM) </div>i know that the water pump pulley is definatly the correct RWD Pulley. I think the issue is just the Crank pulley.
    How much do they cost and is it an easy part to change?
    Jul 2010
    james
    Bentley
    [attachment=25597:car_018.JPG]<div class='quotetop'>QUOTE (car @ May 4 2008, 03:28 PM) </div>what would i need to change? both the crank and water pulley or just the water?
    Jul 2010
    james
    Bentley
    <div class='quotetop'>QUOTE (car @ May 7 2008, 10:24 AM) </div>with closer inspection i think it may be the waterpulley as it's alot shallower than i expected.
    Is the crank pulley ok though?
    Tom
    yeah, just the water pump pulley needs to be changed to rwd. Probably a fwd engine with a rwd water pump so it could retain the clutch fan I think Kaizen Garage have the rwd water pump pulleys
  1. Crank pulley
    By adds in forum Technical - Questions
    Last Post: 21st April 2012, 10:06 PM
  2. BT issue - stalled and could not crank
    By pkjai in forum Technical - Questions
    Last Post: 16th November 2010, 12:26 AM
  3. Supercharger pulley and crank pulley!!!
    By FATPANDA in forum Cars or Parts Wanted
    Last Post: 6th April 2010, 09:29 AM
  4. crank timing pulley
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 14th April 2009, 12:16 PM
  5. Timing pulley off the crank?
    By FKN16v in forum Technical - Questions
    Last Post: 5th June 2007, 07:32 PM
