its not so much running hotter but it will ping unless tuned to the right fuel and conditions.
For best performance, what can you set the ignition timing to on a stock bigport 4age?
pro's and cons?
i don't mind if advancing it makes the motor run hotter. my 4age doesnt budge off C anyway..
any feedback appreciated.
yeah but say if i advanced it 3-5 degrees and ran 95oct would there be noticable power increase?
removed because i can't be 100% in right and don't want to break your engine.
3-5 degrees is jack shit and shoudl run on 95 even on a hot day i'm sure. if it pings then retard it simple as that. the way to induce a ping if its got it, is to go up a hill in a high gear like 4th. detonation is bad. go for a drive and bring a 14mm or 12mm whatever its is socket and ratchet with you.
and if your temp gauge barely lifts from C then you have other problems. liek thermostat or temp sensor.
let us all know how you go
if the thermostat was bad wouldn't it overheat?
and I'm pretty sure my temp sensor isnt hooked up
if the thermostat is stuck open...
