Results 1 to 5 of 5
Thread: Adjustable cam gears.
    Senior Member eightsixboy's Avatar
    Paul
    East
    I'm just wondering if you can gain any power by advancing the inlet cam a fraction? Or is there not much to be gained with the standard cams.
    Also I want to go aftermarket cams eventually but i spoke to a cam regrinder and he said there wouldn't be much to gain unless i went with cams bigger than about 272 on my engine, which ofcourse means aftermarket ecu and alot of mucking around. I was planning on just going 264 inlet and 256 exhaust so i can run the standard computer, and was hoping for maybe an extra 10kw at the engine when tuned.
    Anyone gained anything from 264 or smaller duration cams or is it just a waste of money?
    I'm not looking for insane power, and am happy to keep the standard ecu, but i would like a little more go, my bigport has 71kw atw. I would be real happy with 80kw atw, so about 100kw at the engine.
    Cheers.
    Veteran biggo's Avatar
    Nick
    Noosa
    thought of buying a small port? 100kw ath the crank.
    It always confused me why people buy aftermarket cams with only a short duration. If you went turbo it wold make sense, but seeing as its NA and you want more power, just cough up for an ECU and enjoy
    Paul
    East
    Yeah i think i will just have to save up for a ecu, and go nuts with a big set of cams :teehee:
    Jase
    South Australia
    Glenelg
    71kw atw for a bigport is pretty good anyway!
    Paul
    East
    Yeah i was pretty happy with it. Its got a pod and 2 1/4 exhaust.
  1. Adjustable cam gears
    By adam in forum Cars or Parts Wanted
    Last Post: 28th July 2009, 08:43 PM
  2. Adjustable 4AGE Cam Gears.
    By gumbie in forum Cars or Parts Wanted
    Last Post: 16th April 2009, 07:18 AM
  3. adjustable cam gears 16v
    By julzy in forum Cars or Parts Wanted
    Last Post: 31st March 2009, 08:43 PM
  4. Adjustable cam gears....
    By --Redwork-- in forum Cars or Parts Wanted
    Last Post: 17th February 2009, 03:18 PM
  5. adjustable cam gears
    By fozz in forum Cars or Parts Wanted
    Last Post: 13th April 2008, 09:09 AM
