are the crank pulleys on a 4age the same size as the pulleys on the 4agze ? and are they the same size around the key hole ?
cheers. sam
Same size around key hole, different outside diameter where the charger runs (will make fuck all boost with a ge crank pulley over a gze - ge is smaller outside diameter)
Fine if using it on a turbo setup though![]()
