The crankshaft timing belt pulley is the same for all 16v 4A-GE and 20valve silvertop.
The blacktop 20v and other 4A-FE etc gives different part numbers, but I don't know the difference. They all look the same.
Hey guys does anybody know if the crankshaft timing pulley is the same across all 4A twin cam engines? Or Is the 20V different? My guess would be the same as toyota is usually smart with these things but would like to hear a final word :2thumbs:
Cheers Charlie
Ps: Not to be confused with the actual timing pulley. Ie this is the little gear on the crankshaft I'm talking about![]()
Part number for the silvertop = 13521-16010
Cheers guys! Thx for the help![]()
Let me know if you find one and where from as they have been listed as no longer available.
They are $75 + gst here in NZ, and thats brand new direct from toyota
<div class='quotetop'>QUOTE (stalker @ May 11 2008, 03:54 PM) </div>They obviously still have stock on the shelf which is good cause when i got mine thru toyota they said it was the last in the country and were not available anymore.
They are still available through toyota. Got mine this arvo
<div class='quotetop'>QUOTE (charlie_keto @ May 12 2008, 08:46 PM) </div>Is this the 16v usable one, If so what toyota did you get it through and do you know if they have any more.
A little rule of thumb I found, if a part number ends in -16010, it is probably for or will fit AE86. Not a fact, just a feeling I have as the number keeps coming up.
