Results 1 to 4 of 4
Thread: Fuel regulators ..
    Oldschool Member
    Apr 2007
    i have a problem with my fuel system .. I'm running a bosc 044 fuel pump and its pumping way to much fuel into my motor
    which i think floods it. The standard pressure of a 4AGE is roughly 205kPa to 265 kPa i think but wen i go to check mine with a
    fuel pressure gauge, the needle sits on the pin that stops it from goin round again.
    if i was to get a fuel regulator am i able to adjust the fuel pressure back to standard? and where would i go to purchase one?
    located in syd.
    anyways cheers for reading any help is appreciated !
    Veteran slide86's Avatar
    Huw
    Hills
    is your current reg operating ok?
    do you have the vacumn line hooked up correctly.
    the reg will be fully open at idle, allowing almost all the fuel back to the tank.
    it seems werid that there is that much pressure there.
    how are you connecting the gauge into the system? it should be 'T' eed into the feed side. not just put straight onto the feed line
    Rob
    Moorabbin
    Standard puel pressure reg should be fine for most applications. High pressure might be caused by a blockage in the return line or an undersized fuel line (especially for a pump capable of higher flow). What size is your return line? When I did my 4age conversion I used the fuel breather line on the 4ac setup for the return because it was larger...
    stefan
    vic
    eastern suburbs
    somthing is malfunctioning on your fuel system. i run an 044 on standard fuel lines and standard fuel reg. i get great economy from this setup
  1. NSW WTD ae86 gt fuel tank, pump and fuel line supply
    By smash in forum Cars or Parts Wanted
    Last Post: 2nd February 2012, 09:09 PM
  2. Power Window regulators - bolt in AE86
    By markiitourerv in forum Car Parts For Sale
    Last Post: 9th November 2011, 12:23 AM
  3. Replies: 4
    Last Post: 19th May 2011, 11:28 AM
  4. fuel rail adaptor plate for aftermarket fuel pressure reg
    By 1sik20valve in forum Cars or Parts Wanted
    Last Post: 5th January 2010, 02:18 PM
  5. 4AGE losing fuel supply round corners & when low fuel in tank
    By Sidey in forum Technical - Questions
    Last Post: 11th April 2008, 05:41 PM
