1. sprinter but they might be the same
2. yup
3. yup
cut the sway bar mounts off the s series and get someone with a welder and a hoist (eg local exhaust shop) to put them onto the t-18 diff, use the sway bar to locate them.
Hey everyone. I have a T18 Diff that i want to put into my ADM sprinter. my questions are
1. Do i use the Sprinter 4 links, or the T18 4 links?
2. When using the Zenki small axle lsd, Do i use the same T18 Axles and wheel bearings?
3. With the tailshaft, do i use the T18 rear and the Sprinter front section?
Also any info on adding sway bar mounts would be much appreciated.
Thanks :2thumbs:
2. yup
3. yup
Or buy AJPS weld on swaybar mounts.
Links to the diff are the same.
and then to take it one step further....
if you want to run a Kouki LSD in a T18 housing you can use the MX13 axles
<div class='quotetop'>QUOTE (Meathead #1 @ May 11 2008, 09:25 PM) </div>Care to explain how this works? Here's a comparison pic of an MX13 axle vs a T-series axle.
Something tells me it wont fit.
you have misread....
MX13 axles into KOUKI center....
No i haven't. Zenki T-series axles are 23mm. Kouki T-series are 24.5mm. MX13 axles are 27-28mm. Have you tried it out and it all fits together?
Eddie.
