Results 1 to 10 of 15
Thread: cut rear springs
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    any body ever tried AU XR6 springs cut down in the rear of their 86, i work at ford and have a set lying around, just wanted to know will they go good with kyb sierra shocks
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    Dave
    if they are about 6" round, cut them up and stick them in.
    id assume xr6 might be a bit stiffer? "xr6" sounds sporty...
    sierra shocks to short in my opinion, although people use them all the time.
    check the tech article on rear suspension for other options.
    holden wagon ones are working fine for me, bout 50mm longer (part number 343113 i think)
    - Blaise Pascal
    Richard
    South Oakleigh
    yeah, I'm prob gonna go with monaro shocks as ive got a kit on the 86 and only plan for shitty adm sprinter wheels on the back, yes XR6, stiffer rate, and also fit perfectly on the spring seat on a s series, borg warner, t series, etc.
    SQ ENGINEERING
    NCCE
    Veteran Konakid's Avatar
    Henry
    Eastern
    don't go sierra they are too short, they'll have no droop = not good at all.
    343113 will be sweet with them as ke70dave said, just don't go to low.
    Jan 2007
    cut springs are illegal, and stupid. ring up browns in thomastown just down the road and get a custom set wound for you...very cheap. or drop into carrolls. they're pretty knowledgable.
    Henry
    Eastern
    Cut springs killed my father....and raped my mother.
    Dave
    <div class='quotetop'>QUOTE (hatstand @ May 14 2008, 12:30 PM) </div>
    cut springs + stock (probably stuffed) shocks + un-captive springs +ultra low = dangerous and stupid
    cut springs + short stroke shocks + captive springs + reasonable height + wireties/wire holding springs to bottom spring seat so they can't physically fall out = not dangerous
    everything to do with these cars is illegal unfortunately...
    - Blaise Pascal
    Henry
    Eastern
    <div class='quotetop'>QUOTE (ke70dave @ May 14 2008, 02:40 PM) </div> :2thumbs:
    Jan 2007
    shakes head...people will spend $$$ on engines but still fuck around cutting springs...morons.
    Richard
    South Oakleigh
    well wen your trying to make it to an event in 2 months and your strapped for cash, own an angle grinder and have a free set of springs, chopped will do for now
    SQ ENGINEERING
    NCCE
  1. Replies: 8
    Last Post: 22nd September 2011, 07:29 PM
  2. wtt 6kg rear springs for 5 kg rear springs
    By slippry in forum Cars or Parts Wanted
    Last Post: 26th February 2008, 07:21 PM
  3. CUt Springs
    By upo53r in forum Technical - Questions
    Last Post: 10th February 2008, 10:49 PM
