whaaa why! u better keep this ya dirty bastard
after many hours debating this, ive decided to turn to the dark side and decided to go with a dirty nissan engine.
so my worked NA 4AGE that is sitting in my car atm that hasnt even been started has to go but at the right price.
Specs:
Bigport 7 Rib Bottom End
Small Port Head, Shaved a tad for slightly higher compression)
Fully Ported and Polished, Valves Re Lapped
HKS Valve Springs
Wade 800A Cams (253 at 40 thou)
Techno Toy Tuning Adjustable Camgears
Techno Toy Tuning Velocity Stacks
Techno Toy Tuning ITB Manifold Adaptor
Silvertop Quad Throttle Bodies
Kaizen Garage Extractors (not fitted)
Adaptronic ECU
TRD Ignition Leads
Just had a new timing belt service done and cams dialled in to Wade Spec, to make max power between 3500 - 7500 RPM
Head assembled by head works in carnegie and clearence set to wade spec (10 thou) setting up the head was $900 on its own
This engine owes me well over the $6500 mark, not including the time i took to put it all together.
The bottom end was in the car before i put the rest on, was standard bigport as it was my daily, rebuilt approx 20000kms ago went it went in, has a exedy HD clutch of the same age.
It still needs a tune, ignition timing set, a silvertop 20v TPS plug and a distributor cap seal, the engine has been cranked over but never started, (never cranked with fuel pump on)
Price I'm looking for is $4500, and it will be a bolt in job.
Flame me all you like or throw me an offer
If this doesnt sell, i will keep it a run it in a few events and it will be for sale again as a whole or in parts. early next year
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
Could you explain a bigport 7rib block for me please.
Insert witty comment here....
stronger
wow this thing is nuts...similar to my build lol.....how many rwkw should this put out????
I'm not sure how many rwkw haydenzz as it isnt tuned, had alot of mixed reviews from different tuners, meridian motorsport said around the 170-180hp at the crank. i do wanna finish this beast of a thing as I'm still learning to drift and this has been an ongoing project for a long time, as i said I'm not fussed if it doesnt sell but it will be for sale definetly next yr either together or in peices
SQ ENGINEERING
NCCE
looks awesome man, mines pretty much exact same specs but with 304 hks cams n trd .8m headgasket. would love to see running, but good luck with the sale
cheers, should be a real good engine, but if anyones planning a na build in due time, i got alot of shit you may need
SQ ENGINEERING
NCCE
that looks effing hot.
good luck with the sale man.
I'd be interested in it after you get it running and tuned. As i'd prefer to see it running and drive it before purchasing.
So if you do get it running, send me a pm.
