Results 1 to 6 of 6
Thread: lost my blinkers
    Senior Member GHETTOKE70's Avatar
    Shaun
    Sunshine Coast
    lost my indercators on my ke70 while driving through a puddle fuse isnt blown anyone know any likely cause for this to happen? how do i fix it cheers max
    Senior Member Ksevn-T's Avatar
    LOL!!!
    Wait til it all dries out then test them again.
    数独のガレージ "Sudoku Garage" <3<3<3
    Oldschool Member
    Mar 2008
    let it dry, or take to it with a hair dryer then replace blown fuse...
    most likely cause is some exposed wiring somewhere in the indicator circuit
    Site Supporter Javal's Avatar
    Josho
    ooooooooooooooor, water bridging the power and earth in the indicator itself (cracked / loose lense?), causing the blown fuse.
    callum
    qld
    tully
    he said the fuse didnt blow. probly just loose connections. crack em open and have a look
    your friendly neabourhood electrition. for cash jobs pm me!
    Veteran slide86's Avatar
    Huw
    Hills
    the flasher unit might have crapped itself
    i believe on ke70's its behind the drivers side kick panel
    remove that, turn the indicators on and tap the flasher unit, see if that does anything.
    also check the fuses behind that panel
  1. POLISHING TAILIGHTS AND BLINKERS
    By wide s13 in forum General Topics (No Technical Questions)
    Last Post: 6th March 2008, 10:59 PM
  2. WTB FRONT BAR BLINKERS
    By SKREMN in forum Cars or Parts Wanted
    Last Post: 12th October 2007, 04:11 PM
  3. blinkers
    By diba in forum Cars or Parts Wanted
    Last Post: 19th September 2007, 02:32 PM
  4. LOST
    By us_ae86 in forum Offtopic Discussions
    Last Post: 11th July 2007, 08:29 PM
  5. Question in regards to Blinkers
    By frootloop86 in forum General Topics (No Technical Questions)
    Last Post: 24th May 2007, 03:21 PM
