Results 1 to 10 of 12
Thread: Ae71 dash into ke70?
    Senior Member Ksevn-T's Avatar
    hey all!
    don't like my clock dash and would like to know how much rpm the motors doing. How would i go about puting the tacho dash from an AE71 into a Ke70? is there any modification required? or Is it plug and play?
    Thanks,
    Alex
    数独のガレージ "Sudoku Garage" <3<3<3
    Veteran slydar's Avatar
    Dimitri
    plugs in.
    infact youll find the wire for the tacho pulse might be in the loom already.
    if not you need to disassemble the cluster and trace which one is the tacho single.
    or find out the colour toyota use for the tacho pulse, and make note of which pin it is when you pull the cluster out (or ask some one with an ae71).
    78's
    Aaron
    In the Mountains
    na its wired already, just pull the old one out, plug new one in... it was a factory option so they have the wiring previsions alrady to go.
    I'm sure i answered this question like 2 days ago.... haha
    Elite rthy's Avatar
    Leo
    Tulla
    the wire is indeed already in the loom, get it and plug it in
    Site Supporter Javal's Avatar
    Josho
    Righto - there's something i want to clear up here.
    The plugs for the KE and AE dash are the same, however, are the signals from the oil pressure sender different? i.e. one resistance and one signal or something? (am i making sense?)
    Same goes for the tacho, I've had trouble getting these to work before when using a KE70 tacho dash in a car equipped with a 4AGE, however a Ae71 tacho dash into a 4AGE equipped car has worked fine? halp?
    also why doesnt my digital clock work in my tacho dash?
    it worked when i first put it in?
    and everynow and then i can kind of see it, but yeah most of the time it doesnt
    <div class='quotetop'>QUOTE (grape_moosha @ May 19 2008, 11:32 PM) </div>i have the same problem i think it's just that they are getting old,
    Thanks all! Now i just have to source one for cheap! :2thumbs:
    Aaron
    In the Mountains
    my digital clock works fine?
    sprinter and ae71 have different oil and water (i think) senders, incorrect ones may make it read wrong. same gose for 4ag.
    swap to the ae71 senders and it should fix that problem?
    i have a digital clock out of an t-18 cluster, anyone want it?
    was going to try and convert a ke clock dash to cooler jdmish t-18 spec but CBF...
    my clock stoped working after a after market head unit went in.
    i didnt loop something like earth? or dash light up? lol test light and fixed in 15mins lol
    ae71 parts for sale stripping 3xae71's and a ke70
  1. KE70 / AE71 Custom Dash
    By Bluterus in forum Technical - Articles
    Last Post: 25th January 2015, 10:13 PM
  2. ke70/ae71 tacho dash caboolture
    By kels ke70 in forum Car Parts For Sale
    Last Post: 18th March 2011, 12:18 PM
  3. KE70/AE71 Dash Mat
    By ChuingBeans in forum Cars or Parts Wanted
    Last Post: 13th December 2010, 12:35 AM
  4. AE71 Tacho Dash into KE70
    By Greg in forum Technical - Questions
    Last Post: 29th October 2007, 06:57 PM
  5. WTB: AE71 tacho dash, not ke70
    By Brendo in forum Cars or Parts Wanted
    Last Post: 25th July 2007, 03:50 PM
