Results 1 to 10 of 11
Thread: Cigarette Adaptor not working?
    Hi all
    Does anyone's cigaretta adaptor acutally work? (charge phones and stuff)
    I've tried 2 actual parts and they still don't work.
    I get light in the cig adaptor tunel which says to me theres power going through, but it wont charge any phones or get hot when you push the cap in.
    Any ideas ?
    cheers
    Elite rthy's Avatar
    Leo
    Tulla
    while what your saying about the light meaning power is a very logical assumption would you beleive it isnt the case?
    The light comes off the same circuit as the rest of the dash lights and hence can be on when your fuse for the actual socket is poped. Okay now for starters check the fuse pannel thats in the right kick panel and see if its blown. You could also poke your cigarete socket with a test light or screwdriver.
    30kw club
    <div class='quotetop'>QUOTE (Sam_Q @ May 25 2008, 10:48 PM) </div>Thanks.. I checked my fuse panel already, but will check again anyhow.. ive been getting quite a few blown fuses lately, but I'm pretty sure ive changed all of them.
    I don't have one of those lights to test, but how does the screw driver trick work? is that dangerous at all?
    Elite rthy's Avatar
    Leo
    Tulla
    like shorting it? I don't like that
    I sujest a $5 test light
    30kw club
    Elite rthy's Avatar
    Leo
    Tulla
    oh I forgot to say sometimes the wire clip/lug comes off the back of the socket and you lose power. But my memory is rusty
    30kw club
    Still no luck..
    checked the back ends of the 2 units i have and still no good
    even went and bought a replacement fuse even though the old one is still good.. still no luck. Gotta get me a light pen
    Elite rthy's Avatar
    Leo
    Tulla
    ok grab yourself a cheap multimeter, a $10 one from Jaycar is fine. First push the multimeters black lead onto a bolt on the body (door hinges are also good) the put the red positive onto the center pin of your cig socket. You should get 12V with your engine off and accesories on. If you get that then take a running lead from the positive wire on your multimeter and take it to the positive on the battery, they put your negative wire on your shell of your socket and see if you get +12V again.
    30kw club
    Oct 2007
    just quit smoking... it is cheaper
    Veteran blair's Avatar
    Blair
    SEQ
    <div class='quotetop'>QUOTE (Jamie @ May 27 2008, 05:57 PM) </div>wants to charge his phone bud...
    Oct 2007
    <div class='quotetop'>QUOTE (Blair @ May 27 2008, 06:22 PM) </div>its a joke mate :confused:
  1. t3 adaptor 20v to 16v inlet adaptor
    By 4AGENT in forum Cars or Parts Wanted
    Last Post: 13th January 2011, 12:26 PM
  2. WTB: Cigarette Lighter/Adaptor 12V
    By li21 in forum Cars or Parts Wanted
    Last Post: 12th May 2008, 05:11 PM
  3. H/U stopped working
    By Will(SPA50) in forum Technical - Questions
    Last Post: 17th January 2008, 09:18 PM
  4. handbrake not working as it was
    By deanoo in forum Technical - Questions
    Last Post: 15th November 2007, 06:40 PM
